5.0 xkr air filters
Old Jan 16, 2021 | 04:45 PM
Justtttttom's Avatar
Default 5.0 xkr air filters
I've read that the xkr is sensitive to differences in filter resistances hence batch matched pairs should be purchased, where possible.
​​​​​​I find it slightly hard to believe this is truly a thing though why risk it. Any other opinions/experiences in not getting pair matched?
Does anyone know where I can get pair matched online? Only seen oiled filters coming in pairs and I don't want oiled.
Old Jan 16, 2021 | 05:48 PM
I think that's overly pedantic. Two identical filters (same manufacturer / part number) is perfectly adequate.
I would only consider a matched pair of Purdey's as an essential accessory.
A bargain at 89,500 UKP.
Old Jan 16, 2021 | 09:56 PM
Stuart S's Avatar
Originally Posted by GGG
I think that's overly pedantic. Two identical filters (same manufacturer / part number) is perfectly adequate. ...
Not necessarily, because there may be enough of a flow difference between different lot numbers to trigger a CEL.
https://www.jaguarforums.com/forum/x...esolved-92749/
Old Jan 17, 2021 | 06:21 AM
That was posted more than 7 years ago in 2013. From the OE filters I've purchased in that time, I know JLR have changed supplier three times since then. May be an ongoing issue or may be resolved.
Old Jan 17, 2021 | 01:01 PM
Stuart S's Avatar
Just because advice is old, doesn't mean it isn't still valid today!
I have no problem with aftermarket engine air filters. My point is that if those filters are replaced and thereafter you get a CEL, know that the cause could be mismatched filters.
Old Jan 17, 2021 | 01:44 PM
Cee Jay's Avatar
Charlton Heston? He gave crappy advice.... he told me to buy Pan American Airline stock. What a flop THAT was.
Old Jan 17, 2021 | 01:55 PM
Found some Mann at a good price so I'll have a punt on those. If I get a code, I'll give jag a call.
Odd that nowhere online sells matched pairs though. Does anyone know who manufactures the OE filters? Not bosch is it?
Old Jan 18, 2021 | 07:41 AM
MarkyUK's Avatar
Mine had K&N's fitted from previous owner, changed to a new set of the same at 2019 service and took the old ones and cleaned and reoiled, no issues of CEL's
That said I've a spare set of cheapy blueprint filters that would be fitted if I ever encountered an issue
Old Jan 18, 2021 | 08:02 AM
Stuart S's Avatar
Updating my previous responses, the issue of mismatched filters occurred with 4.2L XKR models. It appears that the 5.0L XKR isn't as sensitive because I searched and didn't find anyone who reported that problem.
Old Jan 18, 2021 | 09:41 AM
MarkyUK's Avatar
Plus point for the 5lt then?
Old Jan 18, 2021 | 11:20 AM
Stuart S's Avatar
There's only one way to find out. Install two brand new filters in your 5.0L XKR, one from Brand A and the other from Brand B and let us know.
Old Jan 19, 2021 | 02:12 AM
neilr's Avatar
The Jaguar part C2P16933 is stamped with "Made in Poland" and the big manufacturer in Poland is Filtron (193/3) whose products do look rather similar.
plight
Jul 29, 2020 07:23 AM
AlexJag
Aug 15, 2019 06:35 PM
Sentinelist
Dec 9, 2014 08:30 PM
Mendo XK
Apr 7, 2013 07:14 PM
GhostriderXKR08
Apr 3, 2011 04:57 AM
