Abs module/dsc/cruise error
Old Jun 28, 2025 | 01:43 PM
davehxk's Avatar
Default Abs module/dsc/cruise error
Hi, as per the title of the thread I've had these errors come up in the last couple of days, also had a random CATS error that only came up once.
Am I right in thinking that it could be a battery issue? Ive just done a 1000 mile weekend trip and the car ran perfectly, it was only a couple of days later the lights have started coming up.
I have done a hard reset with the battery cables but they still come up. the battery voltage this morning was around 12.3v, i have an icarsoft scanner but its with a mate at the min and I won't get it back for a couple of weeks.
I'm thinking it won't do any harm to replace the battery anyway as a start?
Regards Dave.
Old Jun 28, 2025 | 02:16 PM
sov211's Avatar
Your battery voltage should be 12.6 minimum. If the battery has been in service 5 years or more since installation, it is likely due for replacement. And yes, the errors showing can be caused by low battery voltage.
Old Jun 28, 2025 | 02:25 PM
davehxk's Avatar
Thanks for the quick reply, I'll replace the battery tomorrow. When cranking the voltage does go below 10v. Might be a coincidence but the "beep' has recently stopped working when double locking.
Old Jun 28, 2025 | 03:27 PM
kj07xk's Avatar
A ‘sounder’ going bad can be a battery drainer.
Old Jul 9, 2025 | 07:26 AM
davehxk's Avatar
Well the sounder started to work before i stuck a new battery on! I then cleared all the faults and it looks as though I need a new rear abs sensor, all the other lights came back on after a mile test drive.. at least it's a quite cheap fix, the icarsoft scanner has paid for itself already so they are a good investment.
Peter_of_Australia
Feb 20, 2026 04:46 PM
khsjsilver
Jun 8, 2024 11:29 AM
samtimmons
Jun 13, 2018 03:37 PM
vdpnyc
Apr 21, 2014 08:50 AM
SPIJohn
Dec 5, 2013 09:19 AM
