Adaptive Dynamics Fault.
Does anyone have a picture, or can tell me exactly where the sensors are for this system.
I have the warning on the dash. Cleared once before by pulling the fuse and the refitting. Perhaps coincidence. Now on constantly and my code reader cannot see it.
Battery is maintained constantly on CTEK so I know that is not the problem.
Only other thing I've done recently is remove the undertray to check for a leak so perhaps I may have disturbed something when refitting, as this is when the warning became permanent.
Thanks in advance for any useful information.
Maybe this helps X150_2006-2009_Adaptive_Dynamics.pdf
You really need to scan the car with an IDS or SDD, or maybe one of the other aftermarket scanners that can see B, C and U codes.
Without codes, you are kind of shooting in the dark.
The system is quite simple. There are four sensors, one at each wheel and three accelerator sensors. This goes into a control module behind the rear seat that then sends the voltage to each shock absorber.
Get the wiring diagram and have a look. I traced mine to a faulty suspension height sensor. At the control module , 5 volts is sent out to power the sensors and a signal is returned. On mine, 2.8v was coming back from three sensors but one was at zero.
I unplugged the module and checked the resistance between ground and the signal from each sensor. Three were about 470k ohms and the faulty one 30 ohms. To make sure it was not a wiring short, i disconnected the faulty sensor and measured again. Thai time the resistance went to infinity. I then measured the sensor it self and saw the low resistance there too so I knew it was faulty.
I also checked each actuator coil from the shock absorber and these all read about 2.8 ohms and all the same so i knew these were fine.
One final thing I did was unplug the faulty sensor , bridge an output from a good sensor to the faulty ones input on the control module, then start the car.
I got no yellow triangle and was able to select winter and dynamic mode which I wasn't able to do when it was faulty
I finally got a second hand sensor from a XF and fitted it and all came good.
So it can be done with no code reader , it just takes a lot more time to do but is more satisfying.
If you need help, just ask as you do have to be handy with a multimeter
The following 6 users liked this post by m20nuts:
jimbov8 (07-17-2016),
macon6500 (04-12-2021),
Nigwel1058 (03-03-2022),
Overkill (03-19-2020),
Panthro (02-27-2018),
and 1 others liked this post.
I have just fixed mine without a code reader. I had the permanent yellow triangle on the dash.
Overkill (01-01-2020)
The one thing that really bums me out is my ice maker stopped working. Constantly filling old school ice trays is below average. I need your trick reader on that task darnit.
All in good fun!
Just had this come on my 2010 XKR did clear once but perm active
scanned with sdd which is saying code U043A92 invalid date from suspension control module B
Was going to re programme module but thought better of it as car is under jag warranty at present
Where did you got to with your Jimbo?
Resolved
Having finally got round to removing the back seats to get to the module, voltage checks pointed to the front right height sensor being faulty.
Disconnected the arm and operated the sensor by hand and found it to be very ratchety.
Purchased a new one, fitted and now everything is back to normal.
Now back to having some fun.
Thanks for all the information!!
Im having this problem as well but a little different,
ABS not available, DSC not available, Adaptive Dynamics not available.
Also it says my front right tire pressure is low, but I checked it by hand
and it is normal.
Where should I start? I have a multimeter, but do not have proper diagnostic tool.
Guidance please.
and it is normal.
Guidance please.
there was some heavy rains i drove through lately, i'm thinking
one of my height sensors might have been wetted
after that I managed to get JLR SDD working, and did a full scan on my vehicle
Heres what I came up with:
I'm pretty clueless on what to do next.. help!
-Control module output power A Lost communication
with instrument cluster control module
-Front left wheel speed sensor
-Antenna circuit
-Front right height sensor
-Steering angle sensor
-Invalid data received from the suspension control module B
-Invalid data received from ABS control module Invalid data received from ABS control module
-Control module microprocessor B Park aid ignition Number plate lamps
Thanks in advance!
