Advanced Engine Specs (Valve Size, Cam, etc) for Header Calculations
Old Mar 12, 2015 | 09:14 AM
FrickenJag's Avatar
Former Sponsor
Default Advanced Engine Specs (Valve Size, Cam, etc) for Header Calculations
I've been trying to locate these specs published and I'm having a hard time. Does anyone know the following information or where to locate for the 2008 4.2 engine as well as the 5.0? I'm working on a set of tri-y headers. In order to do some calculations, I need to take all of this into account.
Intake valve head diameter:
Exhaust valve head dia.:
Intake lift at valve:
Int. duration @ .050 lift degrees*:
Intake opens @ o BTDC:
Exhaust lift at valve:
Exh. duration @ .050 lift degrees*:
Exhaust opens @ o BBDC:
Intake port dimensions:
Exhaust port dimensions:
Intake lobe centerline
Intake closes @ o ABDC
Exhaust lobe centerline
Exhaust closes @ o ATDC
Thanks in advance.
Old Mar 12, 2015 | 09:53 PM
NBCat's Avatar
These specifications do not appear to be in the Workshop Manual, so you may want to contact JLR directly for such detail.
If you are constructing a new inlet and exhaust system for this vehicle, you may need to disassemble an engine and take the measurements you need independent of JLR.
Old Mar 13, 2015 | 02:26 AM
u102768's Avatar
These are from the 4.2 and 5.0 litre workshop manuals plus a bit from the 5.0L technical guide:
4.2L
Valve head diameter intake (mm) 34.8 - 35.0
Valve head diameter exhaust (mm) 30.8 - 31.0
Camshaft lobe lift intake (mm) 8.50
Camshaft lobe lift exhaust (mm) 8.50
5.0L
Intake valve head diameter:36 ± 0.1
Exhaust valve head dia.:30 ± 0.1
Intake
Opens - 29 degrees BTDC (before top dead center) to 33 degrees ATDC (after top dead center)
Closes - 207 to 269 degrees ATDC
Exhaust
Opens - 244 to 194 degrees
Closes - BTDC 6 to 56 degrees ATDC
Camshaft lobe lift intake (mm) 10
Camshaft lobe lift exhaust (mm) 9.36
From a different source:
The Camshaft Profile Swiching system controls the lifting height of the intake valves. At engine speeds from idle up to the range of 2,800 – 4,825 rpm (load dependent), the intake valves have a lifting height of 5.5mm. At speeds and loads outside of this range, the high lift cam (10.53mm) is used.
Lifting Height Valve Opens Valve Closes
Intake – 5.5 mm lifting height
Opens - 27° BTDC to 35° ATDC
Closes - 187° ATDC to 249° ATDC
Intake – 10.53 mm lifting height
Opens - 37° BTDC to 25° ATDC
Closes - 213° ATDC to 275° ATDC
Exhaust – 9.36 mm lifting height
Opens - 244° BTDC or 194° BTDC
Closes - 6° ATDC to 56° ATDC
Old Mar 13, 2015 | 02:45 AM
Cambo's Avatar
Make sure you have a look at this https://www.jaguarforums.com/forum/g...-2l-s-c-80560/
The branching needs to be as per the drawings in that thread.
Old Mar 13, 2015 | 08:57 AM
FrickenJag's Avatar
Former Sponsor
Thanks for the replies Gentlemen.
I wonder if the duration above for the 5.0 is the same for the 4.2. (I would think the numbers would be close) ?
I could potentially base my calculations for the steps/lengths upon this, I'm just a stickler for precision.
Thanks for the info.
Good link for the cheaper design and yes, that's the exact branching I was thinking with the firing sequence. I'm quite surprised Jaguar didn't go with this approach with the Supercharged setup. Cylinders 6 and 8 are a major concern for restrictive flow and excessive heat. I'm quite optimistic that a well tuned design will make surprising numbers with the exhaust fabricated.
Old Mar 14, 2015 | 02:13 AM
Cambo's Avatar
One thing worth noting, the exhaust ports are different between the 4.0/4.2 and the 5.0
So you will need different flange designs depending on which engine you make the headers for...
BrentGardner
29
Dec 16, 2024 12:13 AM
Bcrary3
Sep 3, 2015 10:36 PM
johanasu
Sep 3, 2015 12:39 PM
Bcrary3
Sep 3, 2015 10:54 AM
stetson1
Aug 27, 2015 07:49 AM
