Aggressive Exhaust
Old Aug 30, 2018 | 06:45 PM
Don-T's Avatar
The 2.25" X-pipe fits OVER a 2.25" ID exhaust. A 2.25" ID pipe will fit sloppily over our 55mm pipes so you need to build up the 55mm pipes to seal into 2.25" and then install the X-pipe over the 2.25 pipe. Been there, done that, no fun. Lot of weld filler.
Old Aug 30, 2018 | 07:32 PM
Cee Jay's Avatar
My exhaust guy built an entire center section with the X-pipe integral to it. He also put factory-type connections on both the front and rear so I can easily swap back to the stock center section, which I kept. He used all 2-1/4" stuff.
Old Aug 30, 2018 | 10:07 PM
Cambo's Avatar
These are the ones I get made locally.
They are done in 2.5" and the ends are swaged to match the 55mm factory pipes.
For whatever reason 2.25" tube is 50% more expensive than 2.5" around here, and in much shorter supply.
Old Aug 31, 2018 | 07:37 AM
Ranchero50's Avatar
Lightbulb
It's because bigger is better don't ya know...
Old Sep 1, 2018 | 02:17 PM
Don-T's Avatar
Had a girl tell me that on our last date....
Old Sep 1, 2018 | 09:14 PM
Ranchero50's Avatar
Wink
That's a terrible way for a girl to end a relationship...
Old Sep 1, 2018 | 09:40 PM
steve_k_xk's Avatar
Besides getting new cats any ideas on reducing the low down rasp of my exhaust
Any suggestions ??
I'm thinking the rasp is obviously due to 100 cell cats and the fact they used mild steel instead of stainless on the down pipes
Old Sep 1, 2018 | 11:32 PM
  #28
kj07xk's Avatar
Any suggestions ??
Just throwing this out there, as I don't have any experience in the area... but if you think some of the rasp may be due to the type of metal used in the pipes, maybe increasing their mass might reduce the vibration of the pipe itself.
What I'm thinking is take a heavier piece of pipe, split it, and use hose clamps to strap the pieces around the current pipe. Alternatively, strap some heavier metal bars to the pipes, to increase their mass, and reduce their vibration frequency.
The idea might be full of crap, but then, so am I.
Old Sep 2, 2018 | 03:13 AM
steve_k_xk's Avatar
Was kind of thinking the same thing but using a heat wrap
Old Sep 2, 2018 | 04:00 AM
  #30
Aonsaithya's Avatar
This talk of adding mass to the downpipes reminded me of this thread, though it's for vibration, not rasp in the note. Bracket part numbers on this thread.
Old Sep 2, 2018 | 08:26 AM
  #31
Ranchero50's Avatar
To kill the rasp you'll need to capture the high frequency sound. Capture the frequency on video, analyze it and build a Helmholtz resonator to capture it. That's what I did for my drone problems and it actually worked.
You could also add a small pair of glasspack style resonators to the mid pipe.
Old Sep 2, 2018 | 06:54 PM
  #32
steve_k_xk's Avatar
Might try the heat wrap out first see if actually reduces the raspy tone
Old Sep 2, 2018 | 07:51 PM
  #33
Ranchero50's Avatar
The wrap would make the temps through the pipes higher which increases the speed of sound and will change the pitch a little bit. It's also horrible on the metal plumbing and not recommended if not needed.
Cavity Resonance
calculator
Cavity Resonance
Wolff87
Jan 1, 2018 03:55 AM
Jaguar Forums Editor
Jaguar Press release
Jan 22, 2016 12:08 PM
jagmt
Oct 2, 2014 09:50 PM
bollocsk187
Sep 19, 2014 12:43 AM
