Airbag removal
Old May 27, 2016 | 09:43 PM
CleverName's Avatar
Default Airbag removal
Greetings!
So who knows how to dismount the steering wheel airbag on our cars?
I've watched various YouTube vids (none dedicated to our year of cars), and have tried to mimic almost all the European processes with no luck.
Even broke down and bought a FleaBay $29 airbag removal tool kit, and am about to surrender after repeated failures.
Anyone have the secret technique they care to share?
Many thanks,
Vince
Old May 27, 2016 | 09:52 PM
jahummer's Avatar
I've removed mine twice and it is not easy. I used the Jaguar airbag tool. The biggest issue for me is when one side released and then I release the opposite side then the other side would snap back in place. Took me about 40 minutes back and forth.
Old May 28, 2016 | 12:39 PM
CleverName's Avatar
No chance you took pics so I can tell what the latching assembly looks or functions like?
This is what I got to work with.... No idea which tool comes close (if any).
Vince
Old May 28, 2016 | 01:04 PM
jahummer's Avatar
This is what you need:
Sorry no pics but you need to extended the steering wheel and turn it 90 degrees from center, this places the right and left access holes within easy reach, now at top and bottom. The tool slides in and you push it to the side to release the wedge tab/clip.
Old May 28, 2016 | 01:21 PM
CleverName's Avatar
Do you recall if you were working up high (towards the rim) or down low towards the hub? Once inside the release slots, there is about 3/4" of up/down play back in there, and I could not really find or feel anything.
Am I pushing a spring wire off a slotted post, like some of the vids I saw (Volvo I think).?
Old May 28, 2016 | 02:10 PM
jahummer's Avatar
The tool needs to be centered, the tabs are plastic wedge shaped. You should feel the tool fit in the slot where the tab is located and then push towards the center of the wheel.
Old May 28, 2016 | 10:28 PM
CleverName's Avatar
Great, that helps, thanks!
Alli Quinninho
Dec 22, 2020 03:00 AM
MHT
Apr 18, 2016 03:51 PM
kreyszig
Apr 14, 2016 04:42 AM
JackJohn
Mar 28, 2016 08:59 PM
