Airbag warning light with code B0070
Old Sep 3, 2015 | 10:44 AM
Jpav27's Avatar
Default Airbag warning light with code B0070
Hi guys, wanted to mention this just in case anyone else has this happen:
Drove to work and home and the car was fine. Went to a store, car was parked for maybe an hour. I got in and started it and the airbag warning light on the dash was on. I drove home. Restarted the car, the light would come on with all the other lights, turn off with all the lights, than stay on steadily. No blinking code, just steady on. Someone posted a list of the blinking codes for that and staying on was listed as "Miscellaneous" (that didn't help). I did an OBD2 scan, and in the restraint control area it had B0070. Which is the driver seatbelt tensioner.
Before I attempted to remove the seat and have a look, I decided to pull the seatbelt as far as it would go, and see if it was caught or twisted. It wasn't. But I started the car and buckled up, and the light is no longer on! So, the seatbelt must have just been caught on something.
A lot of hassle for something simple. So if the warning light is on steadily for anyone, just try tugging the seatbelts a bit, and see if that fixes it first, before you go to too much trouble.
Old Sep 4, 2015 | 12:03 PM
Jpav27's Avatar
Default Update
So the warning light was off yesterday morning, but after sitting in the hot sun in the parking lot at work, the light was back on in the evening. Again no flashing, just on steadily.
This morning after sitting in my garage over night, the light was off again.
Now I am thinking that the warning light has nothing to do at all with a problem with the seatbelt, but is just from the car sitting in the hot sun. I plan to test the battery when I get home, just to see if that could be related in some crazy way.
Maybe my car is just being a brat and needs me to buy her presents.. Something new and shiny should do the trick
Old Sep 5, 2015 | 03:17 AM
Ngarara's Avatar
Could be an intermittent connection that separates when the car gets hot and stuff expands. If it keeps happening, check the wiring to the tensioner for chafing, loose connectors, loose grounding bolts, etc.
Old Sep 5, 2015 | 04:09 PM
Jpav27's Avatar
Thank you. I suspect you may be correct. It was about 10* F cooler on Friday and the light remained off. The light remained off today, as well.
I did test the battery and the CTek had it in the yellow. I set it to recondition tonight.
The weather should start getting cooler, so I will wait and see.
Old Sep 26, 2015 | 03:43 PM
Jpav27's Avatar
Thanks Ngarara, you were correct. The light eventually came on and stayed on. So when I brought my car to the shop for another thing, I asked them to look at this also. The tech there agreed that it was just a loose connection.
Old Mar 21, 2016 | 11:26 AM
pegasoFede's Avatar
hi japv.
same history, absolute same history.
After a parking with high degrees warning light start, during winter it's more difficult
but come again.
during check light go off and after 5 second back on sometimes remain off without
starting engine other times it come also without stating engine.
the only great difference is in the model car not xk 150 but much older xk8 97
Finally how have you resolved?
tku.
Old Mar 21, 2016 | 01:26 PM
Jpav27's Avatar
Hi. Yes. Ngarara was correct. It was a loose connection. I had it fixed at jag. The light has been off ever since.
Old Mar 21, 2016 | 01:50 PM
pegasoFede's Avatar
tku jpav, have he tell about connection? was Yellow connector under driver seat?
i like your car was my dream after my xk8.
Old Mar 21, 2016 | 03:18 PM
Jpav27's Avatar
Thank you. No. I did not ask which connection. Sorry.
Old Dec 16, 2018 | 10:55 PM
OhWhatNow's Avatar
Please excuse me for digging up this zombie, but I want to correct a misstatement made by Plums. I found it strange that Jaguar would wire one side if the repeaters and not the other, so started poking around. Sure enough, the right hand wiring is indeed there. It is a dead ended plug in the space where the ECU is. The wire isn't long enough to reach the badge/repeater,and the connector isn't for it (it's the typical type) , so I suspect there is a pigtail with a part number out there somewhere. Any help with that would be appreciated.
Also note, If you knock the adjacent relay loose the CEL will light up and you will get codes P0031, P0037, P0051, and a C something. Forgot that one, something about a left rear sensor.
Old Oct 26, 2019 | 04:55 AM
mrrossix's Avatar
Great post - hoping it's something similar for an X100? (UK 2002 XKR 4.0)
I found the diagram below:
Looking under my seat though I can't see where this is (ringed on the lower right hand side) - do I need to take something else apart to get to it?
I also 'played' with the item ringed at the top centre, wondering what this was... inside it says SR2220; I know SRS relates to airbags but that may be unrelated - randomly as well there's the number 0049 and this is the 49 airbag error code - pure coincidence though I'm guessing?!
Thanks all
Ross
Old Oct 27, 2019 | 03:01 AM
mrrossix's Avatar
Apologies, above got posted in wrong post somehow... anyway to remove/delete it please?
Old May 10, 2022 | 08:56 AM
leaddog11's Avatar
Great info to have. Thanks
Old May 11, 2022 | 10:48 AM
Cee Jay's Avatar
Resurrected THREE times?
Isn't that a record???
Old Jul 25, 2022 | 05:08 AM
George Abitbol's Avatar
Thanks a ton...I'm having this issue right now and I'll definitely try that!
Old Jul 25, 2022 | 02:16 PM
CONTINUED: Tried it this afternoon upon leaving the office. Pulled all belts all the way to the end. Drove like 45 mins (also to verify the duckbillectomy done yesterday had worked well), no airbag light showing anymore so far!! Thanks again man!
Old Jul 26, 2022 | 06:31 AM
leaddog11's Avatar
Fantastic info Bro. Thanks a lot.
Old Jul 31, 2022 | 03:21 AM
Well, actually I shouldn't have rejoiced too quickly...the warning light is back...
And now it turns back on right after engine ignition...
I guess I'll have to find a way to check the error code and see where it comes from...
Old Jul 31, 2022 | 06:43 AM
leaddog11's Avatar
Thanks for the update. Please keep us posted.
Hold-my-beer
Feb 25, 2022 01:52 AM
Howie
Sep 1, 2016 07:08 PM
mikebaker3
Nov 1, 2015 03:21 PM
Fish13
Feb 8, 2015 10:39 AM
Jimbo
XJ40 ( XJ81 )
Jul 15, 2010 09:57 PM
