Alcon brakes vs XKR
Old Mar 25, 2025 | 02:17 PM
Pastor_x's Avatar
Default Alcon brakes vs XKR
Hi! I am happy to own my Jaguar XK vert 2006. The only thing that slightly mars this experience is the sudden lack of brakes. I recently discovered an advertisement selling Alcon brakes from a crashed car. Here in Russia, these are extremely rare. Seller wants ~3500$ just for calipers. My questions are:
1. Are there aftermarket rotors and pads for Alcon brakes or I will have to buy only original ones?
2. Do any repair kits exist in the world, including seals or other components, for rebuilding these brakes?
3. Is there a significant difference between Alcon brakes and the standard XKR brakes, which I can acquire relatively cheaply, around ~1500$ for calipers set? Are they worth buying?
Old Mar 25, 2025 | 02:39 PM
Cee Jay's Avatar
There is a fellow in here recently who is accomplishing this swap to Alcon brakes onto his NA (I think) 4.2.. He's been running into several obstacles but either just finished the swap or is near completion.
For me, the parts and labor cost don't justify the results. since I don't track anymore. I'm quite happy with my /R 5.0 stock brakes on the street, which would be a close-to parts swap for a non-R car.
Old Mar 26, 2025 | 07:25 AM
badicedog's Avatar
I would be thst fellow… I will be completely honest with you, I would NOT undertake this project again. Replacement rotors are available from RockAuto, you will have to modify many components to make this swap work. Stopping power is improved under hard braking, otherwise negligible. The dreaded parking brake is a nightmare… if you like challenges and projects, by all means have at it. Good luck
Old Mar 26, 2025 | 07:34 AM
Pastor_x's Avatar
Thanks, guys! Decided not to go there)
Old Mar 30, 2025 | 02:14 AM
tmich's Avatar
I'm in the other camp. I did this on 5.0 XKR (more to be done on the rear axle to retrofit). They are better. And they look much better.
And I have one spare set (everything incl new seals, all brackets). I'm in Poland. Shipping cost might be high as it is a heavy stuff...
crashxx
Oct 15, 2021 04:26 PM
AlexJag
Oct 2, 2019 12:27 PM
mosesbotbol
Nov 25, 2012 08:40 AM
Chromey35
Jun 5, 2012 01:40 AM
malx
Dec 16, 2010 09:12 PM
