Annoying rattle under dash in XKR
Old Sep 25, 2017 | 09:11 AM
streaky's Avatar
Default Annoying rattle under dash in XKR
the above rattle appears to in the left hand centre of dash and is set off by any road bump on lhs of vehicle, any ideas?
__________
2007 XKR (added by GGG)
Old Jan 5, 2018 | 08:11 PM
zray's Avatar
I wish i knew. My newly acquired '02 XKR is doing the same thing, but intermittently.
z
Old Jan 6, 2018 | 02:55 AM
Welcome to the forum streaky,
I've moved your question from General Tech Help to X150 forum. Members here with the same model will be able to help.
Old Jan 6, 2018 | 08:48 AM
Ranchero50's Avatar
Modern OEM's are pretty good about securing any loose stuff under the dash so I'm going with something down the defroster vent. Also being CAD designed there's almost no spare room up there. I'd download the service manuals and see what you can do to troubleshoot it. Make sure all the HVAC functions are working correctly etc. Maybe it's something dumb. Good luck.
Probably be less stressful to turn the music up a bit than try and fix.
Old Jan 6, 2018 | 12:30 PM
zray's Avatar
The dash plastic has got too much clearance somewhere. It's the rattle on mine for sure. So I'll turn up the music as suggested (or the rpm's).
z
Old Jan 6, 2018 | 12:43 PM
Schmitty63's Avatar
That's how I block out the noise coming from the passenger seat.
Old Jan 6, 2018 | 02:26 PM
Tervuren's Avatar
If your car is right hand drive, it may be the glove box button?
Try holding it with pressure and see if it goes away.
If it is the glove box button, a small piece of strategic felt will make it go away.
JimC64
Sep 22, 2025 02:52 PM
Jeff in Tucson
May 4, 2012 08:26 PM
dfwx
Feb 20, 2010 12:03 PM
