antenna
Old Mar 23, 2021 | 03:41 PM
John lydon's Avatar
Default antenna
cannot lower my antenna on a 2007 XK8, any thoughts
Old Mar 23, 2021 | 04:01 PM
Cee Jay's Avatar
Fuse, bent shaft, or the motor is dead.
Also, the 2007 model is XK, not XK8. The "8" was dropped.
Old Mar 23, 2021 | 05:14 PM
Craniac's Avatar
Mine wouldn't go the whole way up or the whole way down. If you hear the motor trying to raise/lower the mast, you probably need a new mast. If you don't hear the motor, check the fuse. If the fuse is good, you are looking for a whole new antenna.
Another forum member, "Qwikkitty" posted these instruction:
https://www.dropbox.com/s/2jcbf45vni...pages.pdf?dl=0
I was able to just remove my aerial mast, clean it up, clean the gummy grease off the white plastic geared piece and reinstall. Works perfect now.
Old Mar 24, 2021 | 12:01 PM
007XKR's Avatar
Mine is always down and has been since I got it. I believe it's bent, but I don't try to use the radio, so fixing it hasn't been a priority. I've had plenty of other projects to tinker on with the car. If/when I do fix it, I will probably switch to a different style, dependent upon whether I feel like doing some body work at the same time.
Old Mar 26, 2021 | 06:23 AM
guy's Avatar
guy
Nearly everytime I wash the car, I clean then lube (sparingly) that mast. And don’t use wd40.
​​​@Cee Jay states, its limited to a few simple components. But if its marginally operational, gently ‘helping’ it to full extension, cleaning and lubricating (I just use that majic called 3 in 1) then gently helping it down, it will be back to proper working order in no time.
Daytona
E type ( XK-E )
25
Oct 29, 2020 10:45 AM
racintiger
Oct 22, 2020 08:55 AM
flycasterwa
Nov 12, 2012 03:21 PM
g11snyde
May 4, 2011 05:20 PM
