Antifreeze leak near throttle body
Old Apr 23, 2023 | 04:25 PM
dallenyh's Avatar
Default Antifreeze leak near throttle body
Hi all - this is my first post for my first Jaguar. Looking forward to being part of the forum.
My 2008 XK started having an intermittent leak where I'd get antifreeze on top of the throttle body intake hose.
Today I was able to find the culprit. It's a small hose that enters the bottom of the throttle body. See the attached picture.
I'm unable to see where the other end of the hose goes. It appears to travel under the intake manifold.
Can anyone tell me the name and part number for this hose?
Also, what is involved with replacing it? Hopefully,
I don't have to pull the intake manifold.
Thanks!
Dan
Old Apr 23, 2023 | 05:55 PM
Welcome to the forums Dan,
I've moved your question from General Tech Help to X150 forum. This is the place to post technical questions about your model.
Enjoy the forums.
Old Apr 23, 2023 | 06:27 PM
McJag222's Avatar
Is it leaking near the clamp or further towards under the engine? If it's at or near the clamp maybe it could be cut back and re-clamped?
Old Apr 23, 2023 | 08:39 PM
dallenyh's Avatar
It's by the clamp but the hose is bloated and weak at the end. I'll need to cut off 2-3" inches.
If I can get the proper part, I'm considering taking the last 3-4" of the new hose and splicing it into the old hose where it's stronger.
Old Apr 23, 2023 | 08:41 PM
dallenyh's Avatar
If I can't get the proper hose, I'll just get generic hose and put in an elbow to join it with the old hose.
Old Apr 23, 2023 | 08:53 PM
McJag222's Avatar
If you cut it back 2-3 inches what is the rest of the hose like? I think that is one of the "valley" hoses.The hoses are most likely original = 15 years. It could work as a temp solution.
Old Apr 23, 2023 | 09:08 PM
McJag222's Avatar
Patrick Wong did a full work over on his coolant system - you might get some ideas on where to go:
https://www.jaguarforums.com/forum/x...5/#post1731069
Old Apr 25, 2023 | 10:59 AM
dallenyh's Avatar
Is there a thread on where to buy EOM parts online?
Old Apr 26, 2023 | 08:04 AM
V7Sport's Avatar
Check the forum sponsors for links. S N G Barratt for example
Aj Leduc
May 27, 2021 04:09 PM
EZDriver
Jun 15, 2020 09:28 PM
John Chan
May 31, 2018 10:54 PM
Whiskey Bravo
Jun 23, 2016 08:14 PM
SharpJag3
Nov 15, 2015 04:59 PM
