AP Racing Big Brake kit for XK
Old Sep 30, 2020 | 02:26 PM
badicedog's Avatar
Default AP Racing Big Brake kit for XK
I ran into a video with a XKR sporting 6 piston Calipers from AP racing. Anyone know which model calipers are these?
Old Sep 30, 2020 | 03:06 PM
mosesbotbol's Avatar
Probably the same as used on the Lotus Evora 400.
Old Sep 30, 2020 | 03:16 PM
jahummer's Avatar
Are you looking for a BBK for your car?
The Alcons will fit, as well as well as the Brembo carbon ceramics from the F-Type.
Forum member pauledddy also fitted an AP kit to his.
EDIT: Actually that pic you posted looks like his car
https://www.jaguarforums.com/forum/x...8/#post2151017
Old Sep 30, 2020 | 03:23 PM
badicedog's Avatar
I've been looking for Alcons. I think I have a better chance at Buying a Portfolio XKR.....lol My plans are to enjoy my XK, do upgrades as parts need replacing and eventually when the motor fails go out CRAZY. Either supercharger or Turbo.
Old Sep 30, 2020 | 05:13 PM
Cee Jay's Avatar
The stock brakes are quite capable in all cases short of a race track. With capable brakes, the stopping power comes down to the stickiness of the tires.
Brake FADE and such, that's where upgraded brakes come in, but for normal driving totally not worth the $$$ unless you're just playing around and adding parts Just Cuz.
Old Sep 30, 2020 | 08:01 PM
jahummer's Avatar
For street use the base single piston floating calipers were decent, though prone to fade under continuous heavy breaking. Switching to the Alcons took it too a whole other level even on the street.
The challenge with finding the Jaguar Alcons is not likely the calipers as I see those frequently appear on eBay, but the brackets to fit them to the knuckles. Seems when breakers pull these from cars they must just pull the caliper and leave the brackets behind. And Jaguar no longer has them available for supply, at least not the last time I checked a couple of years ago.
The newer Brembo F-type kits however appear frequently in the UK for very reasonable prices. If I hadn’t gone with the Alcons, I would have preferred the CCs.
Old Sep 30, 2020 | 08:22 PM
Stuart S's Avatar
Note that the Alcon Performance Brake Package was standard equipment for one year only - on the 2008 XKR Portfolio models (Celestial Black exterior with Cremona wheels). Alcons became a $5,000 option on the 2009 XKR Portfolio models (Shadow Gray exterior with Selena wheels), which is why most 2009 models don't have Alcons.
You're better off finding an XKR with Alcons than trying to retrofit them.
Old Jan 17, 2025 | 12:09 AM
badicedog's Avatar
Update...It only took 5 Years but I am the proud owner of Alcon 6 piston calipers. Now I need to source Rotors and pads. Any suggestions?
Old Jan 17, 2025 | 08:49 PM
Stuart S's Avatar
duplicate -: deleted
Old Jan 17, 2025 | 08:51 PM
Stuart S's Avatar
@badicedog Inexpensive Alcon rotors (thanks to @jahummer ) were available from Centric in 2016. I bought a set and they're on my XKR now with no problems. See:
https://www.jaguarforums.com/forum/x...-cheap-171582/
It appears that some are still available. I haven't researched this further, and suggest that you call Parts Geek and see if they have them for front and rear. This is their front rotor, and it's only $106.97!
https://www.partsgeek.com/fzch47y-ja...ake-rotor.html
Of course, you'll need mounting brackets and other parts to do the conversion. It's not a simple swap.
Good luck!
Old Jan 17, 2025 | 10:05 PM
badicedog's Avatar
I bought the set listed in the Marketplace. They come with bracket but Im not sure about the rears, I dont know if the E-brake will work or I have to replace as well.
Old Jan 17, 2025 | 10:07 PM
badicedog's Avatar
I also bought a set of HRE 20 x 9.5 front and 20 x 10.5 rear.
Old Jan 17, 2025 | 10:49 PM
Stuart S's Avatar
New? Used? Which style? Forged?
How do you know they'll fit over the Alcons? If you currently have an OEM spare tire (donut), it won't fit over the Alcons. Lots of details you probably weren't aware of. Are you sure you want to do this?
See my Post $6 in this old thread, and click on the link to Richzak's threads:
https://www.jaguarforums.com/forum/x...pinion-126748/
Old Jan 18, 2025 | 05:45 PM
ericmcn's Avatar
Alcons were first fitted to the 2008/09 XKR-S - limited to 200 units, the USA portfolio spec got some of the XKR-S bits like the brakes - The XKR-S is rare, when you select your vehicle here there is no option but the later facelift XKR-S
This car is a machine, I was a couple of years looking out for one and I will keep it as long as I can
Old Jan 18, 2025 | 08:13 PM
McJag222's Avatar
My non portfolio 2009 XKR came with Alcons. Not sure how many were sold with Alcons. Doing a VIN search on my vehicle does not state Alcons or not.
Old Jan 19, 2025 | 01:06 AM
ericmcn's Avatar
The XKR-S of mine was the first model fitted with Alcon brakes, they were an option after this on other Jaguar XKs along with the forged vortex wheels and the larger rear spoiler.
Old Jan 26, 2025 | 06:54 PM
badicedog's Avatar
I want to express my gratitude to all that have contributed to my project on the Alcon brake upgrade. I will be documenting my progress step by step and suppliers I used for misc parts through the process.
Old Jan 26, 2025 | 08:07 PM
CurtJ's Avatar
I'll be following with great interest. And when you get done and are experienced, maybe I'll bring mine by
Old Jan 27, 2025 | 07:28 PM
badicedog's Avatar
Starting project first thing 8am tomorrow. I've gathered all the required parts, Alcon calipers, brake pads, mounting brackets, correct front and rear rotors and DOT 4 brake fluid (complete flush and replace).
Old Jan 28, 2025 | 07:57 PM
badicedog's Avatar
update... first hurdle. I need to source front and rear brake lines/hoses and mounting brackets for the emergency brake.
