Audio Screen Issues
Old Sep 30, 2021 | 09:42 AM
Crobertrod's Avatar
Default Audio Screen Issues
I’m having some issues with my infotainment screen. The screen stays dark although everything works just can’t get it to turn on. I have a ‘12 XKRS
Any ideas?
thanks
Old Sep 30, 2021 | 09:58 AM
Cee Jay's Avatar
Check the car battery!
98% of the time it is Low Battery Voltage which causes electrical associated problems.
Your battery should have at least 12.6 volts AFTER it has sat unmolested overnight.
Try charging the snot out of it with an actual battery CHARGER and not a Maintainer or trickle for at least 12 hours if not overnight.
You could also have an auto shop or store do a quick Battery Check and Load Check for you for free.
Old Oct 17, 2021 | 11:45 AM
Crobertrod's Avatar
I put in a new battery and changed the fuses but no luck my touch screen still won’t work. I’m not sure whether to order a screen or the CD player…I’ve noticed some say it could be the CD player that is causing the problem. Note: my radio works, my hazards work but my screen won’t illuminate. I can see the imprint of the screen display and the on off switch works but the screen remains dark.
Old Oct 17, 2021 | 12:19 PM
Sean W's Avatar
https://www.jaguarforums.com/forum/report.php?p=2408752
Old Oct 22, 2021 | 05:42 AM
guy's Avatar
guy
had a situation like this once…. it was a loose ground point in the passenger footwell. Located slightly forward of the passenger door lower hinge.
Old Oct 22, 2021 | 02:41 PM
CaptainQ's Avatar
Hi All,
These screens seem to be failing on a regular basis. Jaguar charge (if they have stock) over £1,000 to supply. Despite rumours, the unit is the same as fitted to the XF (very slight difference to metal frame around LCD screen, which isn't a problem). Just make sure that if you try an XF one, secondhand, it is of the same age. I bought one on Ebay for £20 and it worked perfectly. Good luck
Old Oct 23, 2021 | 09:29 AM
Crobertrod's Avatar
Thanks I appreciate it.
Old Oct 23, 2021 | 09:47 AM
jons's Avatar
has only happened to me once, when my ipod cable was loose.
Old Nov 1, 2021 | 02:13 PM
Crobertrod's Avatar
Thanks, I got the screen from 2012 XF but the metal housing is different and I can’t use it. Do I just take off the screen only and replace in my existing unit? Is that what you did?
Old Nov 1, 2021 | 06:43 PM
Sean W's Avatar
assuming you tested the new unit and it works, yes swap the mounting brackets. Check every function.
needanswers
Aug 28, 2023 09:12 AM
JDog
May 7, 2021 12:59 PM
coleman645
Sep 2, 2018 10:29 AM
XFS
XF (X260)
Oct 6, 2016 01:24 PM
Ish
Feb 28, 2015 02:40 AM
