Backup Camera new option
Old Sep 15, 2018 | 10:25 AM
wrair's Avatar
For a garage queen XK, which likely would not have sufficient sunlight to charge the BU camera, is there input for a dedicated power supply?
Also, if one wanted a BU and a front camera, how would that work? I presume that the camera works on only one frequency.
~WRAIR
Old Sep 15, 2018 | 12:24 PM
Stuart S's Avatar
Yes, the license plate frame can be charged using the included USB power cord. I don't know for sure, but I wouldn't leave the USB charger plugged in after the battery is fully charged, as it might damage that rechargeable battery. My XKR is not my daily driver and is covered in my garage and I haven't had any problems with the license frame battery after I initially charged it up when I installed it.
The camera operates at 2.4GHz, so you're probably right, although there might be different frequencies for pairing the frame with the display. You can contact the manufacturer and see if it's possible to use 2 cams, front and rear. Obviously, there's no problem for the newer models with the OEM backup camera that is integrated into the touchscreen.
Here's the link to the Owner's Manual in .pdf format. It should answer most, if not all, of your questions.
https://typesauto.com/collections/au...th-4-3-monitor
Open the link, then scroll down and click on the link to download the Product Manual.
Old Sep 15, 2018 | 01:55 PM
kj07xk's Avatar
Originally Posted by Stuart S
Note that you can also use this as a front camera parking aid to avoid those nasty concrete barriers that are just high enough to damage your front spoiler. Simply use it as the frame for your front license plate if you have one.
I was thinking about that as an option for my Lexus, as its nose is as low or lower than my XK. Stopped by the local Costco last week, but no joy.
I’ll go the ‘hard wired’ route with the XK, as I already have a GVIF to connect to.
Old Sep 17, 2018 | 08:38 AM
LoudHogRider's Avatar
Originally Posted by old_dawg
I don't have a Costco close to me, so no account. But decided this morning to check and find that they now have this camera listed on-line. No indication of in-store inventory.
https://www.costco.com/Type-S-Solar-...100425010.html
Please don't buy them out until I can get a friend to get mine next week
I got my early Monday morning impulse buy out of the way thanks to that link. Much appreciated!
Old Sep 17, 2018 | 11:43 AM
wrair's Avatar
Default called the company
1. the TypeS wireless BU camera only allows one camera input, not dual cameras front and back.
2. The chap who answered said look for other companies that offer dual cameras, but I could not find any similar to this unit on Amazon nor Ebay.
WRAIR
Old Sep 17, 2018 | 02:05 PM
wrair's Avatar
Default TadiBrothers
So I found a company that makes a dual wireless camera LCD display, which toggles between the 2 cameras.
Called the company, and a knowledgeable and pleasant person gave me the parts to configure the LCD for 2 camera; backup and front cameras, which are not the same camera as configured as the backup is higher resolution, receiver/transmitters, LCD monitor (5"). Around $350-400+. In addition, each camera needs 12V power as it is not battery or solar operated.
some SKUs are (put in 'Find' box)
54236
93097
76826
19408
He wanted me to purchase right then, but not obnoxiously. Well, that is too fast for me, being **** about these things.
Has anyone heard of this company?
~WRAIR
Old Sep 17, 2018 | 06:25 PM
Robert Wagner's Avatar
I ordered the camera on ebay.$159.95 a bit more than costco.I'm not a member so add 60.00
and wait 5 days for $185.00. I'll update on friday. Cheers
Old Sep 17, 2018 | 09:06 PM
  #28
Stuart S's Avatar
Are you sure that the Ebay item is the same as this solar powered Costco item? I thought that Costco was the exclusive retailer. Winplus has several wireless models.
Old Sep 17, 2018 | 09:31 PM
I hope it's the right one..https://www.ebay.com/itm/No-Tax-Type...72.m2749.l2649
Old Sep 17, 2018 | 11:45 PM
  #30
kj07xk's Avatar
It’s not unheard of for someone to buy something at Costco and resell it on ebay.
Lots of stuff on ebay can be bought cheaper from a retail or wholesale store.
You need to check before you buy.
Sometimes cheaper on ebay came via a ‘five finger discount’.
Old Sep 18, 2018 | 12:41 AM
  #31
Stuart S's Avatar
Originally Posted by Robert Wagner
It is.
Old Sep 28, 2018 | 04:17 PM
  #32
JaguarJeffrey's Avatar
Costco online has these in stock again. I just ordered one, paid the 5% vig for not having a Costco membership, and will have it within "3-5 business days". Looking forward (no pun intended) to hooking this up on the back of my XKR. $138.59 total.
Old Sep 28, 2018 | 06:01 PM
  #33
A quick update for those of you looking at this option: it works. I've had mine installed and in use for about a week now, and after tweaking a few settings (brightness, timeout delay, lines/no lines, etc.) I'm pleased with the image it presents on the screen. The screen itself nestles nicely in the "cigarette" tray underneath the HVAC controls and is fairly unobtrusive. My only concern is that it looks similar to a black cell phone and someone might bash a window thinking they're going to steal one of those instead. I guess I could unplug it every time I leave the car in a public area, but in general I try to avoid bad areas where that would be a predicable outcome.
One warning: please be patient when you receive your setup and plug in and charge the frame battery for a full 6-8 hours before mounting. If not, it will drop the pairing with the display screen pretty consistently and create the sense that the product is defective. I know this now ...
Old Sep 28, 2018 | 07:00 PM
  #34
Stuart S's Avatar
+1 on everything you said. I unplug my display and lock it in the glove box whenever I park except, of course, in my garage. A minor inconvenience, and a small price to pay for such a great device and perfect, inexpensive solution.
Old Sep 28, 2018 | 07:40 PM
  #35
Cee Jay's Avatar
Dunno..... adding extra stuff to the interior makes me think of this:
Personally, I'd go without a rear camera if it meant adding extra stuff all over.
Old Sep 28, 2018 | 08:14 PM
  #36
Stuart S's Avatar
You must have a lot of little kids in your car if you need that many mirrors and cameras to keep an eye on them! How many rows high do you stack them so they all fit in the back seat?
Seriously, this backup cam display fits in the ashtray and is inobtrusive. See the photo in my Post #11, above.
Old Oct 8, 2018 | 01:36 PM
  #37
AlexKeyWest's Avatar
This thing is a bargain. Took about 10 minutes to install and get working. Many thanks, Q&C!
Old Oct 24, 2018 | 12:37 PM
  #38
Queen and Country's Avatar
Shamefully, I havent had time to even start my car since I last posted.
One has to realize this is the same as taking a cell phone in the car, and replacing the license frame, which also did not come from Jaguar.
And why you can make it a front view camera in under a minute.
This system adds absolutely nothing to the car- not even a hole, not a screw.
Its ingenious compared to what others are doing.
All of them have many more components and crucially, none of them have solved where to put the display. Since every inch of real estate inside a car is spoken for.
As luck would have it, unless you are a die hard smoker who never empties his ashtray, its as if Jaguar made a spot for this display and only this display.
I can see why there is a massive enterprise of folks reselling Costco, Ikea and Trader Joe merchandise, the bloody bureaucracy an these giants is mind-numbing: They refused to sell me one, when they had plenty in stock, just because for some reason they decided they were not going to sell it in the stores, all while I was holding one in my hand that Stuart had reserved a day earlier. So I have had to get one from across the country, despite being the one to post the pic of a shelf full of them. But on the brighter side, the aggravation does help take the edge off the guilt when returning it...after it goes obsolete.
Old Oct 24, 2018 | 01:41 PM
  #39
Cee Jay's Avatar
I have mine hooked up to the main TSD. I also don't have to do anything but put the selector into "R".
Old Oct 24, 2018 | 02:03 PM
  #40
Stuart S's Avatar
How much did the parts cost to do that? I know you're a DIY guy, but approximately how much time did everything take you to get it working? Just curious.
