Backup Camera Retrofit: Pre-2012 XK Models
Old Oct 29, 2012 | 07:51 AM
sorapp's Avatar
I suggest you check with Navtool before you buy. When I contacted them last March they said that you MUST have the screen in Nav mode for the camera to display. For me that is not an acceptable solution. The way JgaXkr describes it is exactly what they told me.
Old Mar 12, 2013 | 04:33 AM
pierbout's Avatar
Navtool is still sold out. But they say they will receive some in 8 weeks
Wait and see...
Old Oct 18, 2013 | 08:36 AM
RacerXK's Avatar
Navtool has said this since your post. Just got an email saying it should be available soon, but didn't get any answers about the concerns posted here regarding having to start the Navigation and accept the video request and then turn it off.
May just give up on this dream an rely on the sensors.
Old Oct 20, 2013 | 10:02 AM
pierbout's Avatar
I agree with you, RacerXK: it seems that they don't really know if they will sell it again one day...
Each time I ask then when it will be available, they say "A few weeks."
Old Oct 20, 2013 | 10:13 AM
JgaXkr's Avatar
I use this company for backup cameras. The XK has to be in the Navigation screen on.
NAV-TV
Old Oct 20, 2013 | 09:46 PM
Stuart S's Avatar
NAV-TV
JgaXkr,
I just checked NAV-TV's website and they show backup cameras available for Jaguar XK models up to 2006. They do not list any backup cameras for 2007-up (X150) models.
What model year XKR is your NAV-TV backup camera installed in? Any idea why they don't show availability for X150s?
Stuart
Old Oct 20, 2013 | 10:03 PM
JgaXkr's Avatar
Call them tomorrow & ask for Bob ext 106 He will sell you what you need. If you have any installation questions let me know.
Old Oct 21, 2013 | 08:11 AM
  #28
RacerXK's Avatar
Anyone know of any rear view mirror with backup cameras made for or to work with the XK 2007 or newer?
Seems like this would be a better answer than messing with the navigation screen every time.
Old Oct 21, 2013 | 02:42 PM
Stuart S's Avatar
Have you installed a NAV-TV system in a 2007-up XK/XKR (X150)?
If so, can you post pictures of the backup camera display on the touchscreen?
It would be very helpful if an actual X150 owner with a NAV-TV backup camera system would share his experience with us.
Old Oct 21, 2013 | 03:14 PM
  #30
R_Rated's Avatar
I've had similar units in the past and modified my factory mirror to accommodate the screen.
Peak 3.5 in. Rear View Mirror Backup Camera at Hayneedle
Old Oct 22, 2013 | 08:30 PM
  #31
Stuart S's Avatar
This is just one of two threads that discuss backup camera retrofit (2007-2011) X150 models.
The second thread is: https://www.jaguarforums.com/forum/x...etrofit-88209/ In particular, see the posts by WhiteXKR and rscultho.
I am eagerly waiting for an update from WhiteXKR on the status of his rear view camera project.
Old Oct 22, 2013 | 09:01 PM
  #32
WhiteXKR's Avatar
The good news is I still plan to do a rear camera version that does not require navigation activation if it proves feasible as my next project...but unfortunately I have no progress to report.
My time has been very limited of late, and all the spare hours have been going towards engineering the XK Remote Top, which is almost done.
This will have some great features though:
-The ability of your remote to control the convertible top from outside the car
-The button inside will have a one touch feature so you do will no longer need to hold your hand on the roof console for the entire top cycle.
-You will now be able to raise the rear quarter windows to reduce wind noise.
I am still working out the last couple of kinks but it will be ready soon. This will be pretty easy to install, but it has proven to be a very difficult mod. to develop for the 2007 and later XKs. The amount of time this has required has set back all my other plans.
Old Oct 22, 2013 | 10:14 PM
  #33
sherbercars's Avatar
THANKS FOR THIS GOOD NEWS, I have a Q. when using the remote.from outside to close the top or open ,will it also lock or unlock the doors ?? by the way on a tv program I noticed someone use a remote to drop the top on a Audi. BL
Old Oct 22, 2013 | 10:26 PM
  #34
WhiteXKR's Avatar
Yes, the car will unlock when the top is dropped and locked when the top is raised with the remote. Operating the top will be a simple two button sequence on the remote.
Old Nov 28, 2014 | 03:54 PM
  #35
WhiteXKR's Avatar
Smile Update on the '06-'11 X150 Backup camera project
Originally Posted by rscultho
Ok - so I traded emails with a guy named Tony at Nav Video. Their video interface connects to the video output of the Navigation unit in the trunk. I originally thought that when they referred to the "nav unit" I thought they really were referring to the computer driving the display.
I have no idea why they would develop a video interface in this way. It makes it impractical to use without significant manual intervention. So, yes, you first have to be in nav mode (which requires several manual steps), then when you switch into reverse you get the reverse sensor image, so then you have to tap the display to get the camera image. Then after switching back to drive you have to tap the display again to go back to normal display.
Not very practical in my opinion. If I can locate a schematic for the display input to the touch screen I might investigate creating a video interface that could be used such that the camera image could be displayed automatically as it should be.
The camera and its activation is a fairly simple challenge. The display is the big challenge.
So, there you have it.
I have installed the backup camera to a 2008 XK. It is quite a pain in having to be in nav mode & then turning off the park aid each time. The unit we used came from Navtv in Florida. The install is easier than splicing into RGB lines on the early cars & also nice to have 12 volts to the tail lamps.
I finally had some time this week to pull the video screen from the vehicle and start digging into the what is needed to interface a backup camera so it switches automatically on reverse no matter what mode the display is in.
I am happy to say it seems entirely feasible!
I will be ordering parts and build a proof of concept demo, then post the results. If all goes well, I will then develop a production version of a well integrated backup camera system. Stay tuned!!
Old Nov 28, 2014 | 03:59 PM
  #36
Stuart S's Avatar
Steve,
That's great news! You did such a great job on the remote top kit that I would be honored to be #1 on your waiting list for the backup camera.
Stuart
Old Nov 28, 2014 | 04:15 PM
  #37
Steve,
Stuart
Sorry Sutart. I already claimed That position , You will have to be happy with #2 LOL Bernie
Old Nov 28, 2014 | 06:27 PM
  #38
Stuart S's Avatar
Bernie,
I'm happy being first in the USA.
You're first in Canada.
We're both first.
It depends on how you define the word "first".
Rationalization is the career politician's stock in trade. Hillary.
Stuart
Old Nov 28, 2014 | 06:35 PM
  #39
Snide72's Avatar
Default First Somewhere
I'd like to be 2nd in the US and 1st in Ohio!
Old Nov 28, 2014 | 11:11 PM
  #40
RedRider48's Avatar
We love you WhiteXKR.......I really don't care if I'm 23rd in line. Just as long as i'm still standing. LOL!
