Ball joint rubber boots
Old Nov 10, 2018 | 12:26 PM
DannyJ's Avatar
Default Ball joint rubber boots
Where can we buy these arm ball joint boots? What is the required size ? The boot breaks much before the bushes and ball arm breaks... Thanks
Old Nov 10, 2018 | 12:36 PM
Sean W's Avatar
https://www.jaguarforums.com/forum/x...d-ends-181759/
Old Nov 10, 2018 | 12:51 PM
DannyJ's Avatar
Hi Sean
I see you you replaced yours a year ago
here is updated link you mentioned
https://www.ebay.com/itm/2x-Polyboot...EAAOSw9mFWJ9~u
These are not the same shape and material as originals.
Can you please share your experience installing them and how they last sine installed?
thanks
Old Nov 10, 2018 | 12:56 PM
DannyJ's Avatar
Old Nov 10, 2018 | 02:14 PM
Sean W's Avatar
You need to measure them with a caliper. I didn't replace mine. Was just quoting a member who did. Sorry, can't be of more help.
Old Nov 10, 2018 | 07:12 PM
Ranchero50's Avatar
Ditto, measure and order them, see what fits and make a note of it for the rest of us.
Old Nov 11, 2018 | 04:46 PM
Brewtech's Avatar
Im curious to know if, ceramic coating, could help protect the rubber boot. I applied some to the rubber seals on th e exterior and its been holding up extremely well. Moving parts is a whole different story though
Old Nov 11, 2018 | 05:17 PM
MarkyUK's Avatar
I'd not coat the boots with anything that could potentially affect it's composition such as a ceramic coating
Typically boots/gaiters last around 8-10yrs if not driven in harsh environments
You could put something like gummi pfledge on them safely though am guessing?
Old Nov 11, 2018 | 07:46 PM
Ranchero50's Avatar
Not these, there are reports of these things failing MOT, getting replaced and failing two years later. They are not honest rubber like in the OP's image, more of an opaque silicone rubber that seems to dry rot really quickly. The joints underneath are some flavor of teflon and wear really well. I don't understand why Jaguar chose that material.
Old Nov 12, 2018 | 05:47 AM
MarkyUK's Avatar
Thanks Ranchero, will look out for them when am next under there
On my X100 in over 13yrs of ownership I only had one fail, so they must have used better stuff back then.
Old Nov 15, 2018 | 08:15 PM
Brewtech's Avatar
Mine are shot, and making some noise at low speed. They were ok, until I though that I could drive it like a Lotus for about 500 miles
Old Dec 18, 2019 | 04:21 PM
GordoCatCar's Avatar
Default Do these use silicon grease?
I'm replacing both front upper control arm ball joint boots on MY2011 XKR. Car has only 24K miles so just replacing the boots and repacking w/ grease.
My question now are the joints lubed with a silicon grease? Sure feels like it.
I measured the ball joint stem at 12 mm and the upper seat diameter at 30.4 mm. (I ordered two different pairs: 12-29-24 and 13-30-22. I let you know which fit better. )
Using "polyboots" generic items off eBay. >> https://www.ebay.com/itm/2x-Polyboot...53.m1438.l2649
Old Dec 19, 2019 | 05:34 AM
MarkyUK's Avatar
Gordo, may be a better post in the X100 forum?
Old Dec 19, 2019 | 07:20 AM
My bad. The vehicle is 2011 NOT 2001. (I made the correction in the post.)
Chuck Schexnayder
50
May 28, 2025 08:34 PM
Johnken
May 21, 2018 02:40 PM
Chuck Schexnayder
Mar 7, 2017 09:06 AM
Rique
Oct 25, 2011 07:38 AM
