Belt change now squealing
Old Aug 29, 2023 | 01:50 PM
dougxk's Avatar
Default Belt change now squealing
Had the serpentine belt changed out at the shop (not dealer but reputable). Now, after car is run a mile or so, I have a squealing noise only at idle. When I rev up the squealing stops. Is it just new belt noise? Should I just add some belt "dressing". Is belt dressing ever a good idea.
Thanks. Yes, I searched a while. 2010 xkr
Old Aug 29, 2023 | 02:23 PM
McJag222's Avatar
I had mine done recently at a Jag dealer - no issues. I'm assuming they used a Jag part. I've used belt dressing years ago - seemed to work ok. Have you talked with the shop that did the work?
Old Aug 29, 2023 | 04:12 PM
RichardS's Avatar
Our belt chirped when we bought the car. Belt dressing would stop it for a few months and then it would return. I also changed the idler pulley to the modified design with retaining ridges as recommended by Jaguar but that did not make any difference. Eventually I changed the belt from the smooth type favoured by Jaguar (manufactured by Dayco) to a more textured design made by Gates. Nine months later and the chirping has never returned.
Richard
Old Aug 29, 2023 | 04:35 PM
dougxk's Avatar
Thanks guys. I have talked to the shop about it, but i was wondering if the belt dressing was a good idea. I appreciate your input. Sounds like the dressing is just a temp fix.
Old Aug 29, 2023 | 04:44 PM
Sean W's Avatar
best dressing is a temp fix. It can last months or weeks. It's easy to spray on (ribbed side only of course). Harmless and cheap. The Gates bet Richard mentions is the long term fix.
Old Aug 29, 2023 | 04:47 PM
dangoesfast's Avatar
Take it back to the shop and have them fix it.
Old Aug 30, 2023 | 06:04 AM
guy's Avatar
guy
… if it was the dealer, the warranty covers parts and service for a year.
And I’m with ’@dangoesfast .
Old Aug 30, 2023 | 12:56 PM
J.J.'s Avatar
Probably good idea to replace the tensioner also. They also might've gotten the rollers greasy.
Old Aug 30, 2023 | 01:56 PM
Tracee's Avatar
My past experience was with the tensioner. Co-incidental that it would happen after the belt change, though...
Old Sep 5, 2023 | 02:15 PM
sony2000's Avatar
Belt dressing could mean W-40, and has worked on other cars.
Old Sep 5, 2023 | 02:27 PM
dougxk's Avatar
Took it back to the shop. They determined it was the tensioner. Should be picking up tomorrow.
Dave Redline
Mar 27, 2021 09:21 PM
David_h
May 11, 2014 09:29 PM
QuikCat
Nov 7, 2013 05:17 PM
