Bluetooth module rebooting console - fixed
Old Apr 27, 2019 | 04:31 PM
trick-1's Avatar
Default Bluetooth module rebooting console - fixed
Hi everyone
Thought I would share in case it helps someone else.
About 3mths ago the console screen started to randomly reboot at least once every time I drove. I finally got it to jaguar service who determined it was due to the Bluetooth module causing errors on the MOST ring.
To confirm the service folks took the Bluetooth module out of the loop and bridged the ring with a fibre patch.
this fixed the issue but of course I no longer had Bluetooth. The suggestion was that I get a new module @ cost of $1000AUD+....I therefore started to look for a good secondhand unit...
As an aside I am also inclined to fix old 1970-80’s computers and design/build electronics. Something in me thought “hey a lot of gear fails due to bad capacitors” I recently fixed the HDMI board in an onkyo amp due to such an issue...hmmm....let’s crack open the Bluetooth module and see what we have...
so some one time later after removing the module, which was an interesting but not horrific exercise, I had the module open and on the bench. I could easily see the 4 surface mount capacitors.
So I got spare capacitors from the parts draws and proceeded to carefully replace them. Values are on the top of the cans 100uF (qty2), 470uF (qty1), 330uF (qty1). I used 16V rated parts.
The result is that the Bluetooth module has now worked for over a week and the console does not reboot.
Your mileage may vary.
But hope that it helps someone.
Attached are some images
Original capacitors - 2 large top right and 2 small in middle. The black bar and blue bar is the negative side.
Capacitors replaces
Old Apr 27, 2019 | 09:22 PM
kj07xk's Avatar
Can’t tell from the photo, was there any bulging in the top of the capacitors?
Had to replace bulging caps in some electronic stuff myself recently.
Old Apr 27, 2019 | 09:49 PM
trick-1's Avatar
Hi there, no nothing bulging....
I took my "queue" from having done similar repairs on equipment such as
Old Apple MAC - https://www.classic-computers.org.nz...eplacement.htm
Onkyo AMP - https://www.workshopaddict.com/forum...-tx-sr606.html
Both have had the can type surface mount capacitors. To be honest it was a hunch that was quick to check and has paid off.
I have lost track of the other gear that I have got working again by replaced capacitors: old apple II and Sun micro power supplies, AWA Valve Amplifiers, GE Clock Radio, various apple computers, IBM laptops...
RippedPuma
Mar 26, 2012 10:43 AM
rothe
Dec 6, 2010 07:55 PM
rothe
Audio/Visual Electronics
Dec 5, 2010 03:38 PM
jya
Oct 15, 2010 01:01 AM
