Bluetooth Problem
Old Aug 5, 2012 | 03:40 PM
mullisrd's Avatar
Default Bluetooth Problem
Apparently the Bluetooth in my 07 XKR may have quit. It was working great until a couple of days ago, now it just says No Phone. When it attempts to search for a phone, nothing happens, I click the Yes button, it does not search. I have disconnected the battery for a few hours and get the same result. Is it a bad Bluetooth module or is there another trick I can try?
Old Aug 5, 2012 | 07:15 PM
Stuart S's Avatar
Did you first go into your phone's bluetooth settings and make your phone "discoverable" so your car could find it?
Old Aug 5, 2012 | 08:03 PM
mullisrd's Avatar
Yes, the car itself does not act like it is searching. The phone had been paired previously.
Old Aug 5, 2012 | 08:16 PM
Gray XK's Avatar
Try turning the bluetooth on your phone off, then back on again. Mine does that on occasion (iPhone 4). Searching for the phone never works but switching the bluetooth off and and back on again works every time.
Old Aug 6, 2012 | 02:47 AM
agentorange's Avatar
Bluetooth: the new non-standard we can all hate even more than Internet Exploder.
Old Aug 6, 2012 | 04:00 AM
sorapp's Avatar
I had a similar problem on a previous car. I found that if I went into the iPhone's Bluetooth settings and deleted the car (on my XK it's call "My Car"), then re-pair the phone to the car, the problem was resolved.
Old Aug 6, 2012 | 07:41 AM
mullisrd's Avatar
I am pairing an iPhone 4. I have did the "forget this device" for the car and all other devices on the phone. When I click the "New" button on the car it does nothing.
Old Aug 6, 2012 | 08:41 AM
mosesbotbol's Avatar
Do other bluetooth devices connect to your phone right now? It could be the phone, not the car...
Old Aug 6, 2012 | 12:34 PM
mullisrd's Avatar
Yes, I am able to pair a Bluetooth headset to the phone.
Old Mar 13, 2025 | 06:45 AM
RWS1965's Avatar
Peoplehere arent reading your pót properly. Basically your phone connection screen ís dead, correct? I have the same problem, Im sure ít the module and needs to be replaced. I đi read herer someone replace the capacitors and it worked.
Dz1rfj
Jul 17, 2018 10:29 AM
Dz1rfj
Sep 16, 2015 03:44 PM
carelm
Sep 5, 2015 01:13 AM
obwoodie
Sep 3, 2015 07:45 PM
laserguy
Sep 3, 2015 02:02 PM
