Bodge job
Old Jul 16, 2017 | 12:08 PM
Don-T's Avatar
Question Bodge job
I just discovered a loose cable tucked up behind the passenger visor that terminates in what looks like a telephone connector. It seems to go into the overhead console. Any idea what it might be before I whack it off?
Old Jul 16, 2017 | 05:05 PM
kj07xk's Avatar
Power for a radar detector or dashcam?
Old Jul 16, 2017 | 06:53 PM
Don-T's Avatar
I just started pulling and it was tucked up under the headliner above the windshield. It went down the A pillar and into the dash. I just cut it off. Hope it wasn't important.
Old Jul 16, 2017 | 07:24 PM
jagtoes's Avatar
So did you put a meter on it to see if it was hot in either engine off or engine on.
Old Jul 17, 2017 | 03:52 PM
Don-T's Avatar
Nah, I found a piece of velcro on the back of the mirror and figured the previous owner had installed "something" that would be held by the velcro and I didn't need whatever it was. My multimeter probes can't get into those 4p4c phone jacks anyway. It appears everything still functions.
Old Jul 18, 2017 | 10:24 AM
JackJohn's Avatar
You might want to open the fuse box in the left driver kick panel. You will probably find the other end of the wire you cut attached in there.
Old Jul 18, 2017 | 02:27 PM
SinF's Avatar
That was a wiring harness for an Easy Button. Now it won't work for you.
Old Jul 18, 2017 | 03:11 PM
Mandrake's Avatar
You might want to find the rest of the wire and remove it, or at the very least insulate the end of it.
Old Jul 18, 2017 | 04:35 PM
Don-T's Avatar
However, if something does go wrong, I know where to look. I hate problems that I don't have a starting point.
Old Jul 27, 2017 | 06:28 PM
Firecat17's Avatar
Better done on your car than mine Don-T...
Like your handle though. I guess next time consider heeding the meaning of the contraction.
Old Feb 22, 2019 | 10:19 PM
Jag-o-nomic's Avatar
Hi All,
I just pulled the trip computer to have a look.
Seems my memory aint what it used to be either.
The LED is infact clear. I notice that a blue diode has been soldered inline which didn't I remember either.
Blue diode appears to have bands marked Brown Black Black Brown Brown.
That clear tap in the second pic is where the strip on the front display picks up its' light source.
Hope that helps.
Cheers,
Nigel
Old Feb 22, 2019 | 11:30 PM
Robman25's Avatar
That’s a resistor not a diode.
Old Feb 22, 2019 | 11:41 PM
sov211's Avatar
Clearly this is in the wrong forum since that is the trip computer from a Series III XJ...
Old Feb 23, 2019 | 12:09 AM
pwpacp's Avatar
At least he now knows it is a resistor & didn't have to bother anyone on his intended page.
X150 guys are such givers!
