Bovee 1000
Old Mar 31, 2021 | 04:31 PM
Nookat's Avatar
Smile Bovee 1000
Hello guys,
Those of you who use the bovee 1000 for streaming music from the phone, do you leave the Bovee connected after leaving and locked the car or do you disconnect it? I was wondering if it uses power after I leaving the car and in the long term could drain the battery.
Thanks 😊 And have a nice easter🐣
Old Mar 31, 2021 | 05:09 PM
DGL's Avatar
DGL
It's powered off with the ignition. It works flawlessly.
Old Mar 31, 2021 | 05:17 PM
tampamark's Avatar
+1 - no issues.
Old Apr 1, 2021 | 01:28 AM
Nookat's Avatar
Thanks👍🏻😊
Old Apr 1, 2021 | 04:05 AM
u102768's Avatar
It does work flawlessly but it actually comes on in convenience mode so isn't ignition controlled in the traditional sense.
As soon as you open the door or unlock the car various modules wake up and one of those powers up the Bovee.
It powers down when the module it is talking to goes to sleep. Locking the door after you exit is the fastest way to achieve that.
Old Apr 5, 2021 | 08:00 AM
jacobsos's Avatar
Default Leave it plugged in
I have left my Bovee plugged in for a couple of years now. No issues.
Old Apr 5, 2021 | 09:41 AM
80sRule's Avatar
Works fantastic and no drain! Plus it makes a neat sci fi beep routine on starting up, and I find it faster to get music going to the speakers than the factory bluetooth in my 2011 Jetta TDI Sportwagen.
Old Apr 21, 2021 | 05:16 AM
Sparkling Shiraz's Avatar
I bought a BOVEE and it did not stream my music just got the pause issue all the time. Are there any easy fixes to this?
Kind Regards
Old Apr 21, 2021 | 09:35 AM
tampamark's Avatar
You must have an Iphone. Load a song, any song, into your Itunes library on the phone. There must be something in there for it to work.
Old Apr 21, 2021 | 09:37 AM
80sRule's Avatar
Kind Regards
What I would do is see if you have any issues when directly connecting a device to the 30 pin connector and if that eliminates the pause issue. I’d also see if you could use the bovee in another place connected to a different 30 pin to see if it works there. Because it could be the bovee but it could be inconsistent power from the cable. Then talk to the retailer you bought from.
Old Apr 21, 2021 | 12:46 PM
StiggyMac's Avatar
With the bovee, the master control is from the XK headunit. Press play there and it will play anything that is cued up by your phone.
Old Apr 22, 2021 | 01:39 AM
Fantastic! Thanks for the info it works a treat. I Downloaded imusic popped one song in and Hey Presto started to play without the irritating pause pause pause.
Much Appreciated to you and the forum
Old Apr 22, 2021 | 01:40 AM
Thanks for the response. Thank to you and the forum its sorted.
Old Apr 22, 2021 | 06:35 AM
J Mosley's Avatar
Default Leave BOVEE connected
Originally Posted by Nookat
Hello guys,
I leave my device connected and have not noticed any battery loss. Peace🙏🏽
Old Apr 22, 2021 | 11:10 AM
carealtor's Avatar
I ran into a small issue when I got a new phone. Android, if it matters. The bluetooth was constantly disconnecting and reconnecting. Very irritating. I finally figured out that it was a setting in my phone that it was trying to download contacts to the car. I unchecked the box and it worked perfectly again.
Old Apr 22, 2021 | 01:50 PM
tampamark's Avatar
Unfortunately for the 1 second pause (no song in Itunes) issue that doesn't work also. I tried it all back in the day before this solution was found.
No worries, whoever discovered this was a life saver. We sent back our Bovee because of the 1 second pause, then a while later this was sorted out as the easy fix. I bought the unit again, loaded something in Itunes, boom bada bing, like you said works like a treat.
Old Apr 22, 2021 | 10:00 PM
pk4144's Avatar
I've had mine for about a week. I've got an iPhone 8. Love it but it's a little glitchy. What I notice:
It can be a little finicky in terms of docking the phone. And the start/stop/pause functions work better if you press the car's touchscreen buttons rather than your phone. I press pause on my phone and often it starts playing again. Not so if I press pause on the touchscreen.
Also, if you're switching between phones you've got to "undock" the first phone (and I find shutting it off helps) before trying to dock the second phone.
And yes I leave it plugged in all the time. No issues on that so far.
Old May 15, 2021 | 02:11 PM
Veesixjag's Avatar
Smile Bovee 1000 Pausing
Just purchased the Bovee 1000 and sure as **** had the pause issue
thanks for this advice , worked a treat , can now remove the 12 year IPod classic I have been using with the 5 year old playlist
Old Jan 10, 2022 | 09:14 AM
ballueder's Avatar
Hi, just got my Bovee but it doesn't power on. When connecting it to a mini USB cable in the house, it powers up, the blue light is flashing and I can connect to it. Does that mean I need to have a separate power source for it? I thought the adapter would power it?
If anyone has any advice on how this works, or if it has a battery build in that needs charging first? I thought I plug it into the adapter and it would power up?
PS: engine was running
Old Jan 10, 2022 | 09:58 AM
J Mosley's Avatar
Default Bovee 1000 pwr
The device does not need any additional power source once it is connected via the iPOD cable. Make sure that your cable is operational by connecting an iPHONE and playing your music files. You may need a serial to lightening port adapter depending on your device.
