Is brake fluid change necessary every two years?
Old Aug 13, 2013 | 09:56 AM
  #41
Mikey's Avatar
Didn't I just provide you with an example of a seized brake caliper in my Miata? If that wasn't caused by old/contaminated brake fluid, I don't know what caused it.
Caliper seizures can be caused by many things other than contaminated fluid. Dust shield failure allowing dirt/salt/water ingress is the most common.
Old Aug 13, 2013 | 10:39 AM
  #42
amcdonal86's Avatar
Sounds like baloney to me.
Old Aug 13, 2013 | 11:11 AM
  #43
Mikey's Avatar
Here's a decent cross section
Most seized calipers exhibit corrosion in the cavity between the (failed) dust boot and piston seal. Corrosion on the brake fluid side is typically minor.
Attached Thumbnails Is brake fluid change necessary every two years?-mump_0209_understanding_ford_brakes_11_z_disc_brake_caliper_piston_seal.jpg
Old Aug 14, 2013 | 08:14 PM
  #44
Steamer22's Avatar
I have become the devils advocate on this subject. I am not advocating not changing the brake fluid, but rather that 2 years is overly conservative. Many years ago (1970's) I was a chassis engineer with one of the Big 3. Co-works who were responsible for brakes told me that brake fluid change was based on the worst case scenario of someone checking the brake fluid every time the oil level was checked (which was every fuel fill)...and the location was humid Florida. They would say "if there is some way we could prevent them from pulling the lid off the reservoir we could extend the fluid change interval. Well that is now the case. How can 2 years still be the same change interval as it was in the 70's when we constantly opened up the reservoir to check the fluid? OK, maybe that is what the manufacturers insist on (their legal depts. want to cover the worst case scenario). When I stopped doing my own maintenance in the 80's (changing brake fluid was a pain) I had the dealer change the brake fluid.....and experienced poorly bled systems several times. Buying a new car every 5 years I just gave up on changing the brake fluid. Since I bought my '04 Lincoln LS I decided not to change the fluid and have not had any issues. I'm a sample size of "one" which is of no statistical consequence, but it will be difficult to convince me that a 5 year change interval in a dry environment is wrong. OK, maybe 4 years to placate the attorneys. But 2 or 3 years...be my guest. BTW, amcdonal 86, how old was your Miata when the brakes seized and what were the symptoms of the seizure (failed to brake or locked up)?
Another PS: my neighbor has an '08 car with over 90,000 miles and has never changed his engine oil. As wrong as that is, maybe I'm doing the same thing with my Lincoln's brakes. So, who am I to say. Hey, change your brake fluid every 2 years...forget what I said as nobody agrees, I'm just the guy who saw a flying saucer in my backyard.
Old Aug 14, 2013 | 09:34 PM
  #45
Mikey's Avatar
You are not alone. What is the plural of advocate?
Old Aug 14, 2013 | 10:20 PM
  #46
Stuart S's Avatar
...What is the plural of advocate?
Lawyers!
Old Aug 14, 2013 | 10:30 PM
  #47
Mikey's Avatar
Originally Posted by Stuart S
Lawyers!
So saying 'devils advocate' is redundant?
Old Aug 15, 2013 | 08:20 AM
  #48
mosesbotbol's Avatar
Just changed the brake fluid in our Range Rover, it has 70K and was looking dark/dirty. Brakes feel is better now.
Old Aug 15, 2013 | 11:55 AM
  #49
user 2029223's Avatar
Banned
I once had a 54 Buick that lived in Alabama. In the Winter of 60/61 (maybe 61/62) we had a freeze where the temp dipped below 20 degrees F and for 3 days. We thought the world was coming to an end.
Anyway, that car's brake fluid froze and locked the brakes for a week together with 100s of other cars in Huntsville. Some lessons come hard.
Old Aug 15, 2013 | 01:29 PM
  #50
Mikey's Avatar
That makes perfect sense. Cars in that era has open master cylinders- a vent hole in the lid that freely allowed air to enter/exit as the fluid level in the reservoir changed. That meant a fresh load of moisture-laden air with each application of the brake pedal. The fact that your car had enough water in the system to freeze when it was 6-8 years old is no surprise at all.
Cars since the late '60s-ish have had sealed master cylinders that isolate the fluid from the air by using a diaphragm or bellows. No more air entering the chamber through normal use.
In those days, we used to open the master to inspect the level on a frequent basis and add fluid as the shoes wore. Today's cars have see-though reservoirs and contain enough fluid to accommodate 100% wear on all four sets of pads- each of which obviates the need to remove the cap.
BrentGardner
29
Dec 16, 2024 12:13 AM
Rupesh
Mar 25, 2016 03:33 PM
niner nellie
Sep 1, 2015 10:53 PM
nelsonht
Aug 30, 2015 06:01 AM
dpappyp
Aug 27, 2015 06:31 AM
