Brake upgrade for 2009 XK
Old May 11, 2019 | 05:04 PM
badicedog's Avatar
Default Brake upgrade for 2009 XK
Serious question... the brakes on my XK feel a it spongy. There is plenty of pads left and are factory Jaguar. They are also a dust tornado! lol. Alcon brakes are impossible to find, been looking. Any other options that are avail? Thx
Old May 11, 2019 | 06:24 PM
kj07xk's Avatar
Are you sure you don’t just have an air bubble in a line? Spongy is not a term I’d use for my XK brakes. Maybe just blead the lines.
Old May 11, 2019 | 07:19 PM
badicedog's Avatar
I don’t have any reason to suspect an air bubble since service history is at dealer.
Old May 11, 2019 | 08:23 PM
steve_k_xk's Avatar
Over time water also gets into the lines affecting the braking system, as kj said perhaps it's time to bleed the system
Old May 11, 2019 | 08:55 PM
Tervuren's Avatar
Sponginess is going to be part of the hydraulics or inconsistent power assist.
When was the last time brake fluid was changed?
Old May 11, 2019 | 10:02 PM
badicedog's Avatar
As far as I know, never
Old May 12, 2019 | 12:47 PM
JagV8's Avatar
Change it and bleed thoroughly.
If still spongy, check none of the flexible hoses need replacing.
Old May 12, 2019 | 01:28 PM
Stuart S's Avatar
Originally Posted by badicedog
... Alcon brakes are impossible to find, been looking. Any other options that are avail? Thx
You need more than just rotors and calipers to retrofit the Alcon Performance Brake system to your XK. You'll also need brackets and parking brake parts. It can (and, as I recall, has) been done but it's very expensive, particularly if you have to pay for labor. Maybe for an XKR that's tracked, but an Alcon conversion doesn't make sense for an XK.
Old May 12, 2019 | 06:56 PM
badicedog's Avatar
Will do a brake fluid exchange/flush and bleed the brakes. Thanks
Old May 13, 2019 | 08:23 AM
Ranchero50's Avatar
It also shouldn't be horribly expensive to do the //R upgrade from salvaged parts. I'd buy the rotors and pads new. The rest is bolt on parts from the S type, XK and XJ donors.
newtojag2018
Oct 4, 2018 01:05 AM
Vinnyboy
Sep 23, 2013 08:25 PM
jwmciti
Jan 27, 2013 03:22 PM
nalleyjagparts
VENDOR 'For Sale' Classifieds
Jun 21, 2011 03:54 PM
JagJames
Mar 8, 2011 11:59 AM
