A bushing noise
Old Jul 7, 2025 | 02:45 PM
sony2000's Avatar
Default A bushing noise
The squeek is unusual. At a slow speed over speed bumps, it doesn't squeek, but it does, rolling on an average road. The crazy part, is that it seems to be coming from the firewall area at the top of the transmission. Could that be the engine mount that was temporarily removed to change the alternator?
2007 XK, 60,000 miles. Upper control arm and right tie rod changed historically. Suspension inspected by wheel alignment staff this week.
*noise
Old Jul 7, 2025 | 09:08 PM
Stuart S's Avatar
Please create a signature that includes your X150's model year, engine (normally aspirated or supercharged), body style (coupe or convertible), and other distinguishing features. Your Public Profile was no help. How many miles? Have any bushings ever been replaced?
Old Jul 8, 2025 | 07:32 AM
sony2000's Avatar
There is a control arm without a ball joint called a Front Lower Rearward control arm. I wonder if it could the source of the squeek?
Old Jul 8, 2025 | 03:14 PM
HealeyJag's Avatar
Default ??
*noise
They didnt replace the motor mounts when replacing the alternator.
Had that plus belts and all pulleys...at 70,000 miles..
All labor not duplicated..
Old Jul 8, 2025 | 07:37 PM
sony2000's Avatar
As well, I had them change the pulley, tensioner, strap and water pump. I have a trick for squeeky bushings. But it will be hit and miss approach.
Old Jul 10, 2025 | 02:57 PM
sony2000's Avatar
The follow up.is that I went for a drive to cottage country. It gave the brakes and the transmission a work out. Then I put on a new set of tires, closer to the original diameters of 100 or less. Bushing squeek has now departed! So now onto other annoyances.
Old Jul 13, 2025 | 02:01 PM
sony2000's Avatar
I am now hearing a loose ball joint on the left side over small bumps. With other cars it was the sway bar links that went first and the wheel aligner said my left tie rod end was good. The new link should get a new M10X65mm bolt and nut.
944xjs
Sep 9, 2020 05:58 PM
Ingo85
Sep 10, 2018 01:58 PM
Anthony8858
Oct 29, 2016 04:58 PM
Rutty
XJ40 ( XJ81 )
Nov 1, 2014 09:29 PM
jjones91
Jan 31, 2009 09:59 AM
