Groaning noise
Old Jul 12, 2025 | 01:34 PM
Ghost60's Avatar
Default Groaning noise
Hey, guys I have 2007 jaguar xk, its making a groaning noise when starting and running also a coolant leak, could this be from the water pump, please advise trying to do work myself and need a lil advise troubleshooting, please any suggestions
Old Jul 12, 2025 | 02:04 PM
Cee Jay's Avatar
Does your wife ride along with you???
Old Jul 12, 2025 | 02:20 PM
Ghost60's Avatar
Old Jul 13, 2025 | 09:13 AM
jahummer's Avatar
Not likely the water pump as there are other locations far more common on these engines such as expansion tank, throttle body heater hose, etc. Best get a pressure tester and pressurise the circuit when it's cold and you'll see leak locations like a perforated water balloon.
Old Jul 13, 2025 | 09:40 AM
Ghost60's Avatar
I failed to mention, my belt broke and was idling up and down in neutral, at start ups, could that be a pulley bad or bearings?
Old Jul 13, 2025 | 09:52 AM
jahummer's Avatar
Bearings would make noise, could be a frozen tensioner, how old is the belt?
Old Jul 13, 2025 | 11:33 AM
Ghost60's Avatar
Thanks, Im an ol chevy Man, this my 1st Jaguar new to thier qwerks and werks, I'll look there as well thanks
Old Jul 13, 2025 | 01:44 PM
sony2000's Avatar
For coolant leak check the valley of the V8 close to the coolant tank. Sounds as if your belt is toast. The alternator might have seized up.
Old Jul 13, 2025 | 07:13 PM
Ghost60's Avatar
Thanks,again guys, I pulled the cross member out and took hood off,able to access water pump, definitely the issue wobble and stuck against water pump itself, which caused the belt to break, ordering water pump and thermostat housing ,thermostat as well, thank u all for input this forum is awesome 👌🏾
Mikejacko
General Tech Help
Apr 3, 2023 07:22 AM
tbrian01
Feb 17, 2017 02:18 PM
Pagline
Mar 5, 2015 01:19 PM
