A/C blowing cold only above 2000rpms
Old May 19, 2018 | 03:53 PM
Peter Ucinski's Avatar
Default A/C blowing cold only above 2000rpms
I got my 2011 XKR last weekend I have my first issue with it.... A/C only blows cold air when I'm going higher speeds and RPMS are above 2000, below 2000 rpms there is no cold air just ambient temp...
I left the car at dealership yesterday so they could do A/C diagnostics and today they came up with compressor needs to be replaced... and that would cost $2300!!!!
I think they are out of their minds , isn't compressor either work or it doesn't what RPMS have to do with compressor as it runs on belt with constant speed... unless I'm wrong here
Anyone had similar issue? I have all Sunday to troubleshoot this problem so any ideas would be greatly appreciated
Old May 19, 2018 | 05:05 PM
Patrick Wong's Avatar
Odometer reading?
The A/C compressor is powered by the serpentine belt driven by the crankshaft pulley, hence the compressor rotates at varying speed as the engine speed varies.
You might try hooking up to the system with manifold gauges to see what is the low and high side pressures at engine idle speed. Maybe the system would benefit from the addition of some R-134a.
If you conclude the compressor does need to be replaced maybe you could locate a used unit to reduce the repair cost.
Old May 19, 2018 | 05:47 PM
jagtoes's Avatar
1st either yourself or an AC shop should check the system pressure. There must be freon in the system if you still get cooling. Next you can buy replacement compressors for $300 -$900 with and without the dryer. I would look around and find a good AC shop and have them take a look.
Old May 19, 2018 | 08:20 PM
Mufc's Avatar
Its the DPS valve sticking. An indi will replace it with the updated part for $600. Including recharge, diagnostic, parts and labor. Jaguar dealers want to ingnore their own technical bulletins and replace the whole compressor when a $200 part has failed. Google JTB00380NAS1.
Old May 19, 2018 | 09:11 PM
davchr's Avatar
Another excellent example of why I don't let dealers touch my cars, except for warranty work.
Old May 19, 2018 | 09:42 PM
I was looking at that TBS before... just not 100% if the cause of this is no cold air below 2000 rpms. did you have the same issue?
it looks that removing the Compressor is the most labor intense part..
Old Feb 20, 2020 | 09:34 AM
Randy Mounts's Avatar
old post but good info. mine is in for this right now
Arabham
Dec 8, 2017 10:20 AM
Bryan Fisher
Feb 16, 2016 05:13 AM
jukes4me
Dec 18, 2013 11:10 PM
Vinarama
Jun 15, 2012 10:02 PM
Bacardi 151
24
May 29, 2012 05:03 PM
