Can AC be done anywhere, 2012 XKR
Old Apr 14, 2018 | 02:25 PM
DublDwn's Avatar
Default Can AC be done anywhere, 2012 XKR
So just want to be overly sure but if I need the AC system recharged, etc can I take it to any good AC place, nothing crazy or special needed?
2012 xkr
Old Apr 14, 2018 | 03:31 PM
pwpacp's Avatar
I recharged mine DIY with a kit from Autozone. Recharge is anything but difficult, however; if it needs service greater than that, DIY would be out of the question.
Old Apr 14, 2018 | 03:53 PM
Sean W's Avatar
Nothing magical about the Jaguar A/C, but if you need a recharge, you have a leak. The system is sealed. So that said, it can get pricey because it's a Jaguar.
Old Apr 15, 2018 | 10:14 AM
trkyam's Avatar
Modern clutchless A/C systems are sealed but they do slowly leak overtime
and need a recharge after about 8 years or so. I would go to a shop
and have it vacuumed out tested and recharged with gas and oil.
its about $150-200
Old Apr 15, 2018 | 08:26 PM
Mufc's Avatar
Have the A/C shop check the pressures first. Hopefully it will just be low on Freon and show low pressure on the low side. If you have high pressure on the low side and low pressure on the high side it will be the DPS valve. Quite a common failure point on these cars.
Old Apr 15, 2018 | 09:51 PM
trkyam's Avatar
Do you happen to know what the cost is for replacing a DPS valve
and recharging?
Old Apr 16, 2018 | 09:50 AM
Mufc's Avatar
DPS valve is around $200 and 3 hours labor. I was quoted around $600.00 all in. Having it done on Wednesday
LantanaTXSuperXJ
Mar 24, 2017 09:06 AM
goodz4u2
Oct 14, 2016 08:30 AM
jackals
Jul 19, 2011 02:17 PM
saustin1974
Feb 14, 2011 09:39 PM
Eric
Jan 6, 2010 06:26 PM
