Can Locking 'Chirp' Be Enabled?
Old Mar 13, 2008 | 12:19 AM
rogerdodger's Avatar
Default Can Locking 'Chirp' Be Enabled?
Hi Guys:
Asked my dealer if they would enable the 'chirp' confirmation when locking doors (standard in some markets, I believe) and they said it can't be done.
However, they did enable the daytime running lights for me, which one of their techs previously told me couldn't be done, either!! He said they didn't have the DRL software!
So, the question is, can the 'chirp' be enabled on a 07 XKR and, if so, how long should it take them to do??
Thanks - Roger
Old Mar 13, 2008 | 06:31 PM
jag_genius's Avatar
Default RE: Can Locking 'Chirp' Be Enabled?
i think you can i will check tomorrow.. shud take 10-20minutes
Old Mar 13, 2008 | 06:40 PM
FactoryJaguarTech's Avatar
You have to write the car configuration file. It can be enabled and the drl software thing was BS. You can set for Canadian or Scandinavian drl.
Old Mar 13, 2008 | 06:47 PM
jag_genius's Avatar
i like the scandanavian lights.. fog with headlights are cool looking
Old Mar 13, 2008 | 08:56 PM
Thanks for this. I will ask my dealer again to enable the chirp.
I wish I had known about Scaninavian DRL. It would be cool to have headlamps and foglamps on together. Mind you, having said that, I heard that the front wheel has to come off to change a foglight bulb. I wouldn't want to bother with that every time the foglight bulb burned out!!
Roger
Old Mar 13, 2008 | 09:14 PM
ibjags's Avatar
not sure about the other dealers in the area,
but our dealer has a flat 1.0 charge for changing options using IDS
Headlites etc
Old Mar 14, 2008 | 06:01 AM
Same here.
The wheel does not need to come off to change bulb.
Old Mar 14, 2008 | 09:35 AM
GhostriderXKR08's Avatar
ORIGINAL: FactoryJaguarTech
Same here.
Yup....I was able to get to the foglight by turning the wheel all the way to one side although it would be much easier to work with the wheels off.
philwarner
28
Jul 11, 2017 10:21 AM
jluckcuck
Nov 6, 2015 07:49 AM
millertic
Sep 30, 2015 08:11 PM
Bigvettefreak
Sep 28, 2015 03:03 AM
