Catalytic Converter Fault
Old May 11, 2022 | 12:03 PM
britishcarnut's Avatar
Default Catalytic Converter Fault
I have a 2007 XKR with 54K miles and got a check engine light. I took it in and the first time they said it was for the left catalytic converter. They reset the message and a few days later the light came on again went back in and they said that now it shows both cats need to be changed. They checked the car and said that they don't find any restriction in the flow of the exhaust. I haven't noticed any change in the performance of the car.
Is there a sensor that could be causing this fault to show up? I've never seen or heard of a cat failing at only 54K miles. I have only had 1 cat fail and that was at 160K miles. I've put over 300K miles on cars without a cat failure so this puzzles me.
Any ideas?
Dennis
Old May 11, 2022 | 01:41 PM
Canadacat's Avatar
I have the same thing with close to those miles. I switched o2 sensors and came back the same . I have a an O2 sensor spacer I am gonna install . Car runs perfect.
Old May 11, 2022 | 02:24 PM
Cee Jay's Avatar
People are going to scream at me, but I also had a CAT EFFICIENCY code come up. I asked my friendly local Euro Mechanic about it, and he said he gets fantastic results with Catalytic Converter Cleaner about 60% of the time.
I tried some, and I haven't had the code return in almost two years now.
Simple, cheap and easy.
You could at least TRY it before panicking or throwing money at stuff.
Old May 11, 2022 | 03:57 PM
RichardS's Avatar
I've never tried that but I have tried cylinder head gasket repair fluid and, somewhat surprisingly, that did stop leak so I'm not knocking anything.
Richard
Old Jul 30, 2022 | 03:39 PM
I used the Catalytic Converter cleaning fluid. At first it didn't seem to work but after I drove the car for awhile the light went off and has stayed off.
Thanks for the advice.
Dennis
Supercharged Jag
Apr 17, 2018 01:11 AM
howm02
Mar 25, 2018 09:02 AM
bostongrun
Nov 26, 2013 02:39 PM
romoan22
May 13, 2011 01:40 PM
DiamondCrystal_XJR
Feb 21, 2011 11:58 AM
