CEL come on, 2008 XKR
Old Feb 17, 2015 | 11:56 AM
agentorange's Avatar
Default CEL came on, 2008 XKR
Driving back from Arizona yesterday when the CEL came on after climbing the 93 out of Kingman heading for Vegas. I had stopped in Kingman so we could stretch our legs but I didn't gas up. Last time this happened the evap system had thrown a code as I drove the car back from Palm Springs the day I bought it.
The connection for me is that both trips involve rapid changes in elevation and the codes were set a few miles after a stop. Is the evap system on these cars overly sensitive/plain cranky? I'll get the code looked at tomorrow. Car runs just fine.
Old Feb 18, 2015 | 03:02 AM
JagV8's Avatar
First thing is to get and post the actual code number(s).
Old Feb 18, 2015 | 10:28 AM
No CEL this morning. My buddy's code reader pulled P0101 from memory. Supposedly this is a generic MAF/VAF code. Any ideas?
Old Feb 18, 2015 | 02:00 PM
Ngarara's Avatar
From the manual:
P010100: Mass Air Flow (MAF) circuit - range/performance
Possible Causes:
• Blocked air cleaner element
• Leakage from air intake system
• Engine breather leak
• MAF sensor sensing circuit - high resistance, intermittent short to ground
• MAF sensor supply circuit - high resistance
• MAF sensor failure
Old Feb 18, 2015 | 08:19 PM
Thanks for that. Guess I'll have to wait and see if it was a diagnostic glitch or a sign of further trouble down the road. The car has less than 35k miles on the clock, so a MAF failure would be a bit of a bummer on that basis.
Old Feb 19, 2015 | 12:05 AM
NBCat's Avatar
If the MIL comes on with altitude changes, what is the condition of the air cleaner element and have you checked for any possible vacuum leaks from mis-fitting hoses? Have you looked at fuel trims to see if there is any indication of lean mixture?
GordoCatCar
Jan 2, 2017 01:10 PM
AzzaXKR
Sep 27, 2015 07:25 AM
swetnK
Sep 24, 2015 07:55 AM
hhv00586
Sep 18, 2015 08:59 AM
Dz1rfj
Sep 16, 2015 03:44 PM
