Center armrest compartment
Old May 2, 2021 | 06:56 PM
Baxter3319's Avatar
Default Center armrest compartment
I am trying to remove inner compartment box. I find no screws or fasteners. Can I get some help.
thanks in advance.
Old May 3, 2021 | 07:36 AM
Stuart S's Avatar
Bruce,
If you're trying to remove the cupholders, they're a friction fit with no fasteners. Simply pull straight up and they'll come out. You can then use that space for additional storage.
I'm not sure about the rear compartment. It might be part of the console assembly and not separately removable. If that's what you want to remove, why?
Stuart
Old May 3, 2021 | 08:44 AM
Baxter3319's Avatar
Default Center glovebox
Cup holder is easy. I am trying to get the liner completely out. I need access to the wiring under that center compartment.
Old May 3, 2021 | 09:24 AM
kj07xk's Avatar
I ‘think’ you need to take out the whole console.
It’s been a few years since I had mine out to do some installation work, and I don’t recall the compartment being removable (at least from the topside), as I needed to cut a hole in it to route a wire out of it, so I think I had to cut it after turning the console sideways.
Old May 3, 2021 | 10:49 AM
Stuart S's Avatar
Open the link to this .pdf, (Attached Files, below), and scroll down for detailed removal instructions.
If this was helpful, press the button on the bottom right.
File Type: pdf
mcook
Oct 5, 2018 01:38 PM
Stuart S
Sep 27, 2018 09:36 PM
JaggyJeff
Aug 4, 2017 05:06 PM
anthawk
Jun 24, 2016 12:55 PM
Mcdna311
May 30, 2013 04:03 PM
