Changing front crankshaft seal, what else should I do while it is apart?
Old Aug 24, 2024 | 06:44 PM
JagReese's Avatar
Default Changing front crankshaft seal, what else should I do while it is apart?
I have a 2007 XK with almost 200k miles. The engine sounds great but had a really bad leak. I am in the process of changing my front crankshaft seal. I have radiator removed so I have complete access to the front of the engine. So I want to know what else I should do while it is open.
I have already changed valve cover gaskets and plan on changing oil pan gasket because I can see that someone was already poorly done it. I also am replacing driver side motor mount and flushing all fluids.
Old Aug 24, 2024 | 10:55 PM
kj07xk's Avatar
Don’t know if or when you’ve done the following, but if not recently:
- Plastic thermostat housing and thermostat.
- Water pump.
- Coolant hoses
Old Aug 25, 2024 | 04:09 PM
steve_k_xk's Avatar
I would also add idler pulley whilst access is available
Old Aug 25, 2024 | 07:06 PM
panthera999's Avatar
Get the one piece water pump.
See this: https://www.jaguarforums.com/forum/x...0/#post2587348
Good luck
Old Aug 28, 2024 | 01:20 PM
JagReese's Avatar
Thanks I have these things on order now.
Old Sep 2, 2024 | 07:58 AM
fritzthecat's Avatar
I think you should win friends and influence people by posting a how-to on that front crankshaft seal! JMHO.
JetJaguar
Mar 5, 2021 07:42 PM
Lagonia
Sep 2, 2016 07:33 PM
o1xjr
Mar 30, 2014 05:15 AM
wotcham8
Jun 5, 2013 03:24 PM
Davejapan
Sep 26, 2011 09:48 PM
