Check engine light P010B
Old May 10, 2020 | 08:54 AM
Overkill's Avatar
Default Check engine light P010B
I had a check engine light come on. Code is p010B. I switched the MAF from side to side and the light came back on. I'm not sure where to go from here.
Old May 10, 2020 | 10:00 AM
pwpacp's Avatar
Try changing air filters.
Old May 10, 2020 | 11:41 AM
Overkill's Avatar
Long story short the left air filter is a stock replacement and the right is a k&n. Could that be a problem?
Old May 10, 2020 | 11:44 AM
Cee Jay's Avatar
Yeah, it is. You need two new K&N filters. OR, get ONE more, then clean and mist both of them, same time. The airflow between the two MAFs has t be within each other by a tight margin.
Old May 13, 2020 | 12:42 PM
gkubrak's Avatar
What do you mean 'mist'? Is that when you put the grease around the egde of the filter? I've never understood the point of that.
Old May 13, 2020 | 01:31 PM
Overkill's Avatar
You lightly spray the filter with filter oil.
Old May 18, 2020 | 05:49 AM
Overkill's Avatar
UPDATE
I replaced the k&n filter on the right with a paper filter to match the left side. It's been a week and the light hasn't came back on. Hope this helps others with the same problem.
ek993
Oct 24, 2014 07:34 AM
magnum454
Apr 14, 2014 05:29 PM
magnum454
Apr 11, 2014 10:02 PM
Noxparadise
May 4, 2012 12:09 PM
jazzwineman
17
Jun 29, 2011 05:57 PM
