Check Pedestrian System repair cost...
Old May 2, 2023 | 12:34 PM
jackson999's Avatar
Default Check Pedestrian System repair cost...
Hi, can anyone tell me how much the Check Pedestrian System fault has cost to repair? I've got the fault and was told it'd be about £500 to fix if both sensors need replacing behind the bumper but, has anyone actually had this fault repaired for less than that?
Any advice would be much appreciated. Thanks.
Old May 2, 2023 | 01:14 PM
They've gone up a lot since I did my 2007 XK in 2017 when the sensor was under 70 UKP. The cost from Jaguar is 150 UKP each although aftermarket parts specialists are around 125 UKP.
I removed the front bumper to replace them but you'll find forum posts which show it can be done without dismantling.
Old May 3, 2023 | 02:39 AM
JonWat's Avatar
I had mine replaced by my local Indy last December
2 sensors cost £225
Labour was 1 hour £70
Old May 3, 2023 | 04:38 AM
jackson999's Avatar
Hi John, many thanks for that reply. Just out of interest, who was your local Indy? If they're near me, I could look them up as a possible alternative to mine...
Thanks.
Old May 4, 2023 | 03:22 AM
JonWat's Avatar
Mistermatic, a long way from you
Old May 10, 2023 | 12:40 PM
jackson999's Avatar
I've been told my Pedestrian Control Module is dead (C2P17579, or 7W8314B654AM or 7W8314B654AJ) so I've managed to pick up a second hand unit. Hopefully this will sort the issue. If not, the next port of call will be the sensors which, as it's a 4.2, shouldn't mean the bumper needs to come off, which will help with the bill.
I will update if this sorts the problem...
Old May 11, 2023 | 03:33 AM
JonWat's Avatar
Well, six months after having both of my sensors replaced the dreaded message came back yesterday. Maybe it was a one off glitch, I'll let you know.
Old May 11, 2023 | 01:44 PM
There's a '99 repeats' count on the error code before it becomes permanently displayed.
Old May 12, 2023 | 03:26 AM
JonWat's Avatar
Originally Posted by jackson999
I've been told my Pedestrian Control Module is dead (C2P17579 or 7W8314B654AM or 7W8314B654AJ) ..
Where did you get the second two part numbers from, I can find nothing on google although part number C2P17579 is available for £335???
Redescape
Jul 13, 2020 07:59 AM
tseeley
Oct 19, 2018 09:59 AM
bobilism
Feb 20, 2017 04:37 AM
Rramshur
Oct 13, 2014 07:36 AM
echosixnovember
Sep 7, 2010 08:25 AM
