Clean MAF sensor.... or replace?
Old Mar 22, 2021 | 07:44 AM
Scott in PA's Avatar
Default Clean MAF sensor.... or replace?
Last fall during our 2300 mile New England jaunt the car threw a CEL code that alerted me to a MAF sensor. I cleared the code and have not had it come back since.
My Spring service is next week... should I have them clean the sensor, or just replace it?
Old Mar 22, 2021 | 12:54 PM
JagV8's Avatar
So long as you have (pending) P1111 I'd at most clean it.
If instead you have P1000 I'd worry about why and leave MAF alone unless you find a real reason to do anything.
Old Mar 22, 2021 | 01:34 PM
Found it! It was a P0101 - Mass or Volume Air Flow Circuit Range/Performance Problem.
Again, no running issues at all!
Old Mar 22, 2021 | 02:14 PM
trkyam's Avatar
There are alot of reasons for sensors to throw codes and typically
they are NOT due to faulty sensors, they are due to intake leaks which
cause the sensors to report incorrect air volumes.
the other reason is dirty sensors, the MAFs can be removed from the wheel well
without jacking up the car, it takes some finesse and the exact angle to slip them out
but I did it and cleaned them. I used a tiny alan wrench and slowly removed the 3 screws.
Old Mar 22, 2021 | 08:09 PM
Ranchero50's Avatar
I'd just reset it and keep going. I get them all the time running the interstate. I also took off the little high water intakes from the front of the air filters so it's easier to get the unbalanced airflow codes. If I drive it around town a couple trips they'll reset on their own. I really need to pull the nose off and connect the filter boxes together with some 3" dryer hose behind the filters. PITA
Old Mar 23, 2021 | 09:25 AM
gkubrak's Avatar
Check your fuel trims for an air/vacuum leak. Driving with this condition will damage your engine in the long run.
Old Mar 23, 2021 | 01:45 PM
gbmarc's Avatar
It's more like wishful thinking that your MAF will be dirty. It's a bit fiddly but not hard to remove and you'll find it perfectly clean, I'm sure. I agree with Gkubrak.
Old Mar 23, 2021 | 06:55 PM
trkyam's Avatar
Dirty MAFs will report the incorrect amount of air (underreport) this is measurable and common.
if you add that with incorrect or dirty filters, and/or intake leaks you will end up with a check engine light.
A dirty MAF is not typically visually dirty to naked eye, also there are multiple sensor wires in our XKR MAFs
one wire is visible the other 2 are not visible and internal to the sensor, you must spray out all directions.
jczaban
Oct 30, 2018 03:59 PM
EZDriver
Oct 18, 2017 05:58 PM
EZDriver
Feb 11, 2016 08:17 AM
Jon89
Mar 23, 2012 09:40 AM
htkenan
Dec 29, 2011 01:31 AM
