Clicking sounds at warm idol
Old Jun 24, 2020 | 11:14 PM
alexstockman's Avatar
Default Clicking sounds at warm idol
Hey friends,
Recently got an XK (2007 X150), very happy with it so far. Looked very clean and my mechanic gave it a green light when I took it in for a pre-purchase.
Anyway, I hear a clicking sound sometime. Usually when it’s warm. I think it started as I’ve been driving it more consistently. It was sitting on the lot for a while. It may just be during idol but that may just be when I notice it. It sounds like it’s coming from the the drivers side of the engine. It’s not constant but kinda follows a sort of syncopated beat if you will. I’ve attached a video.
I’m not too concerned (maybe I should be) but I’d like to figure out what it is or at least get some reassurance it’s no big deal. I’m about to take the thing on a five hour road trip so I want to be sure everything is plum.
would love some direction,
Thanks,
Alex
Old Jun 24, 2020 | 11:26 PM
Default Video:
Looks like the video didn't attach. Here's a link to a google drive video.
Sorry I'm pretty new here.
Thanks,
Alex
Old Jun 24, 2020 | 11:45 PM
De5in's Avatar
You might be surprised how often what sounds like a mechanical clicking like that is actually exhaust.
Old Jun 25, 2020 | 01:33 PM
SeanU's Avatar
And the injectors are noisy as well.
Old Jun 25, 2020 | 03:20 PM
Stuart S's Avatar
Sean U,
You have a 2011 XK and are used to hearing the tick tick tick from your fuel injectors. (I hear that noise, too, from my 2013 XJ 5.0LSC). That noise is normal and is a characteristic of Direct Injection, which uses very high pressure fuel pumps. Jaguar introduced DI with the 5.0L engine for the 2010 model year.
The OP has 2007 XK, which has the 4.2L engine. It does not have DI or the high pressure fuel pump. I doubt that his noise is from the injectors.
Stuart
Old Jun 25, 2020 | 09:54 PM
peterv8's Avatar
Thanks,
Alex
Why not open the hood, might be easier to hear!?
Old Jun 26, 2020 | 05:41 AM
guy's Avatar
guy
Belt tensioners?
Old Sep 5, 2023 | 04:16 PM
RDE's Avatar
RDE
Hi did you ever figured it out? I have the same noise on my 2013 XK
Old Sep 5, 2023 | 06:41 PM
McJag222's Avatar
I think he may have switched idols.
Old Sep 5, 2023 | 06:55 PM
trkyam's Avatar
Air conditioning compressor makes that exact sound when its cycling.
Try turn off your AC, if it stops the noise, then you found it. Perfectly normal
Old Sep 5, 2023 | 07:20 PM
RDE's Avatar
RDE
It was clicking when AC was ON before I replaced the drive belt and belt tensioner. Now it only makes it under the load when turning the wheels or switching to drive.
It still might be the idler pulley. Just want to see if anyone had similar issues. Thanks
Old Sep 6, 2023 | 12:07 PM
RDE's Avatar
RDE
did you mean bad ideler pulley?
Jeep2Jag
Sep 22, 2014 02:08 PM
jagtoes
Jun 18, 2014 11:32 PM
Ipc838
Sights N Sounds
Oct 25, 2011 10:42 PM
I <3 X-Type
Sep 15, 2010 01:30 PM
JagMan
Feb 25, 2008 10:23 AM
