Climate Control Not Working
Old Jul 7, 2016 | 06:07 AM
Knomad's Avatar
Default Climate Control Not Working
Nothing related to the climate control seems to be working on our 08 XKR.
No fan in automatic or manual mode, no air (hot or cold) from any of the vents.
The blower motor fuse (F34)in the rear seat fuse compartment looked good.
Anything else I should check before I make the dreaded trip to the dealer?
Old Jul 7, 2016 | 06:16 AM
Stuart S's Avatar
Try replacing that.fuse with another one of the same size from that fuse panel that you know is good. Sometimes looks can be deceiving.
Does your A/C compressor click on and run? Any other fuses?
Old Jul 7, 2016 | 10:33 AM
Jacsun's Avatar
I only have an 07 electrical drawing (attached. P.27) but it looks like there is a relay in that same rear seat fuse box (aka Auxiliary Junction Box). It is R1. If fuse #34 is in fact good, I might buy one or try swapping out the relay with an identical one from another spot and see if my blower works then. (For example, If I was sure R3 is the exact same color/type of relay and my car was the car in the drawing, I would use that one since it looks like it feeds the rear window heater and the convertible top latch...I would just avoid operating those in any way for my experiment).
https://www.jaguarforums.com/forum/x...xk-how-121629/
Old Jul 11, 2016 | 03:57 PM
Knomad's Avatar
Jacsun - thanks for the electrical diagrams.
I have voltage to both sides of the fuse - next is the motor. On the other side of the motor is the Control Unit Blower Motor Front which gets it signal from the Automatic Temp Control Module.
Anyone know where these control modules are located?
Old Jul 11, 2016 | 04:38 PM
Sean W's Avatar
From my 07 repair manual:
The ATC (automatic temperature control) module is mounted on the end of the blower motor casing, behind the instrument panel. The ATC (automatic temperature control) module processes inputs from the TSD, the control switches located below the TSD, and the system sensors. In response to these inputs, the ATC (automatic temperature control) module outputs control signals to the A/C (air conditioning) system and the heating and ventilation system.
In addition to controlling the A/C (air conditioning) system and the heating and ventilation system, the ATC (automatic temperature control) module also controls the following:
• The seat heaters. For additional information, refer to Seats (501-10 Seating)
• The rear window heater. For additional information, refer to Glass, Frames andMechanisms (501-11 Glass, Frames and Mechanisms)
• The windshield heater. For additional information, refer to Glass, Frames and
• The exterior mirror heaters. For additional information, refer to Rear View Mirrors (501-09
Rear View Mirrors)
• The steering wheel heater (if fitted). For additional information, refer to Steering Column
Switches (211-05 Steering Column Switches)
Two electrical connectors provide the interface between the ATC (automatic temperature control) module, and the vehicle wiring. The ATC (automatic temperature control) module uses hardwired inputs from the system sensors, the LIN (local interconnect network) bus to communicate with the stepper motors and the medium speed CAN (controller area network) bus to communicate with other control modules on the vehicle.
Old Jul 11, 2016 | 04:42 PM
Sean W's Avatar
Here's a diagram
Old Jul 11, 2016 | 04:45 PM
Knomad's Avatar
Another thought just crossed my mind. I had the vehicle at the dealer for maintenance in May and they replaced the cabin filter. Could there be something they did or didn't do that could be related?
Old Jul 11, 2016 | 04:48 PM
Sean W's Avatar
Maybe this is better
Old Jul 11, 2016 | 10:42 PM
Jacsun's Avatar
I guess anything is possible but changing the cabin air filter was a very simple under-the-hood process which requires no touching of anything electrical.
Admittedly I am not the best electrical person but since you had the tools to check voltage at the fuse you might want to try looking up under the passenger footwell and disconnecting the plug to the blower motor. There may be a thin "decorative" panel you have to remove to access the parts under there. The blower motor is pretty obvious with the wires going into it and 3 mounting screws. With the plug disconnected turn on the climate control and fan and see if you are getting voltage across the two leads that plug into the blower motor. I just did it on mine and with the car not running got 12.25v with fan on full and 10.15V with fan on first setting (but disconnected from the blower motor). If you have voltage I think the control unit is fine and you are left with a dead (open) blower motor.
Old Sep 25, 2016 | 08:32 AM
Knomad's Avatar
Just thought I would update this tread.
In troubleshooting the problem, I found I had 13.5 volts at the motor, so that eliminated the fuse and relay. I then bench tested the motor which worked fine.
That left the most likely problem being the Blower Motor Control Module. I went ahead and ordered the part (Airtex WMA 4P1652) from RockAuto. Total price including shipping a little over $80. Easy to install - just drop the panel under the dash on the passenger side (3 clips) and remove the 2 screws holding the module located just behind the courtesy light. (note: the light is hot, best to remove it from the holder and get it out of the way).
Old Sep 25, 2016 | 09:58 AM
kj07xk's Avatar
And?............... (i.e. did that resolve the issue?)
Old Sep 25, 2016 | 10:45 AM
Knomad's Avatar
The issue is resolved! Thanks to all who contributed to this thread.
Old May 12, 2025 | 07:01 AM
Mikesoja's Avatar
Not to restart such an old thread but I have a similar issue on my 07 xkr. When I turn on the climate, it sometimes turns on and at other times it won't it stays completely dead no fan or cold/hot air. It's completely random. I also noticed if it does work it's only the heat and not the A/C. Would this most likely be the blower control module that you replaced?
Old May 12, 2025 | 07:04 AM
guy's Avatar
guy
Perhaps, these are the symptoms of the failing module/resistor.
FWIW, I'm on my 3rd module and 2nd motor.
Old May 12, 2025 | 07:16 AM
Mikesoja's Avatar
Oh wow, I guess I'll start with the module, I'm sure these are all original parts still, so its probably time for a replacement. I'll order the part and update once installed!
Old May 12, 2025 | 09:17 AM
daley9023's Avatar
YMMV, in my case it had been caused by the common water back-fill issue from the condenser drain. It had actually seized up the fan, which then fried the blower motor resistor (or heater control module, it seems to be called the same thing - part C2Z6538). It's only about £15 or so (I actually found it much cheaper to buy it for a Land Rover Discovery 3 rather than a Jaguar - same part, vast difference in price!) - two screws and plug and play into the wiring harness - near the fan motor itself, under the glove box. Other than cleaning the fan motor out and getting it free again, I haven't had any issues.
Old May 15, 2025 | 06:54 AM
Mikesoja's Avatar
Oh wow that's interesting! I got the blower resistor but now I'm hesitating to install it because it has been working on all speeds consistently now :/ i replaced the cabin filter.. it seems the previous one was also installed with the airflow going the wrong way... what I'm having an issue with now is no cold air at all. So I may have a leak or condenser issue, I'm not sure where the fill spot is located either on the ac line. I'll have to double check online.
Old Mar 25, 2026 | 02:32 PM
1stLeaper's Avatar
Default ATC/CCM SDD programming
I’ve determined the ATC module is the issue. I purchased a used replacement with exact same numbers as original. It now needs to be programed by qualified person using Jag SSD.
Here are the particulars have a 2007 Jaguar XK (X150).
I replaced the ATC/CCM (climate control module).
Current symptoms:
  • no blower
  • no heat/AC
  • no heated seats or steering wheel
  • screen works normall
I need:
  • SDD session
  • confirm module is visible on network
  • configure/program ATC/CCM
Anyone have suggestions for a remote programmer ?
thx
Old Mar 25, 2026 | 03:46 PM
guy's Avatar
guy
@1stLeaper (nice avatar name ;-) Firstly, I am not suggesting your diagnosis process is inaccurate. But it is a rarity that the ATC/CCM module requires replacement.
What is common is a situation whereby the module cannot be activated as there is not enough power (voltage and current) to allow the module to activate. Also, the fan resistor is known to go.
I'm hopeful your battery registers 12.6v, 6 hours following any charging event. If it does not, even a running engine may not be enough to activate the module.
(A suggestion from one with much experience on the matter)
Cheers.
Old Mar 25, 2026 | 06:01 PM
Sean W's Avatar
I didn't realize the ATC was anything more than plug and play. If it does require SDD, you need to put your original back. When changing parts that require programming, SDD requires you keep the original part in place until it tells you to remove it and replace. It's a specific process. I agree with @guy - check power first. Does your control panel operate all other functions? Can you walk us through how you determined it was the ATC? what codes are thrown? You would typically need SDD to narrow the problem down to the ATC, which is, as guy points out, rarely fails. replace the fuse and test the relay R1 - lower right relay in the aux junction box
