climate control question
Old Oct 2, 2015 | 06:56 PM
Typhoon320i's Avatar
Default climate control question
I can't seem to figure out how to just blow outside air in without setting the temperature. I just want fresh air from the fan with the windows up because open windows get loud at freeway speeds. Am I missing something simple? Thanks.
-2007 XK
Old Oct 2, 2015 | 09:50 PM
Stuart S's Avatar
You will always have to set the temperature; if you want the outside air to be neither heated nor cooled, set the temperature all the way down and then turn off the AC compressor by using the touchscreen:
1. On the Home screen, touch CLIMATE. That brings up the Climate menu.
2. On the CLIMATE screen, touch ECON, which turns the AC compressor off. The light on the AUTO rotary control knob will turn off to show that the compressor is off.
You can control the fan speed with the AUTO rotary control knob. To turn the AC back on, press the AUTO button on the rotary control knob and it will illuminate to show that the compressor is on.
I hope this answered your question.
Stuart
Brook
Oct 4, 2015 12:42 PM
gshyne
Oct 2, 2015 01:53 PM
Nic1635
Oct 2, 2015 01:30 AM
blackenedindustries
Sep 30, 2015 10:17 AM
dmatthewman
Sep 30, 2015 10:10 AM
