Comprehensive “walk around” checklist for a 2013 XKR..XKR in general.
Old Mar 6, 2023 | 11:26 PM
VegasFPace's Avatar
Default Comprehensive “walk around” checklist for a 2013 XKR..XKR in general.
I’d don’t see mention of one in the sticky section…
is there a list or guide that a new user could follow while checking out a prospective car. Perhaps including common issues or things to look for that may not jump out etc.
interior…
under the hood..
etc
more visual stuff and functionality checks of items on the car. Not talking about compression checks..oil analysis things that require wrenching. I’d like to follow an organized list….like a check list format
2013 XKRs is the car I in question for me, I’d assume a similar list would work well for any XKR.
thanks guys
Old Mar 6, 2023 | 11:43 PM
ralphwg's Avatar
The best thing to do IMO is to get a pre-purchase inspection from the local Jaguar dealer. It is the same as a CPO inspection and should cost around $500. It would not hurt to take it to a Jaguar certified body shop. Our cars are all aluminum. Good luck!!
Old Mar 7, 2023 | 12:58 AM
VegasFPace's Avatar
thanks...Yeah the PPI is on the list, the dealership is booked up though.
Old Mar 7, 2023 | 05:38 AM
+1 to inspection.
A good reference for prospective purchasers is:
The Essential Buyer's Guide - Jaguar NEW XK 2005-2014 by Nigel Thorley published by Veloce Publishing in 2015 (ISBN 978-1-845848-06-4 UPC).
Old Mar 7, 2023 | 08:42 AM
V7Sport's Avatar
+1 on the PPI and Thorley book. Maybe there is an independent Jaguar specialist shop you could get in sooner.
Also review the documented maintenance history.
Old Mar 7, 2023 | 12:48 PM
VegasFPace's Avatar
Got it in at Guadin JLR here in Vegas, on the 20th, $420 bucks for a PPI, not bad at all. Details and drama to follow Im sure!!
Old Mar 7, 2023 | 12:55 PM
Sean W's Avatar
thanks guys
Suspension Bushings - they wear with both use and age. Sometimes it's just the boot covers, but not always. That should of course be part of your PPI but it's a common complaint on all XK variants.
A couple of things that separate the 5.0 from the 4.2, SC or not. The 5.0 engines have a history of water pump issues and the timing chain tensioners is also a prevalent issue in the 2010 onward (5.0 L).
You can look in the other forums such as the F-Type and XF and you'll see those same issues crop up.
Consider having your inspector listen to the engine on cold startup - not sure if there's any other premature sign of the tensioners failing than the death rattle. Also have them look at the water pump weep hole for leaks.
I know those aren't walk around items but you'll want to have them checked.
Leather separation is a problem on the dash primarily, but also check the door cards. This is a common Jaguar complaint with their modern era cars and can easily be spotted in a walk around.
Old Mar 7, 2023 | 06:47 PM
Jaggyx's Avatar
Did you end up buying the XKR-S? If so, welcome to the family. I've had mine for about 6 months now and adore it.
Old Mar 7, 2023 | 08:10 PM
McJag222's Avatar
Jaggy - why did you sell the F type?
Old Mar 7, 2023 | 10:18 PM
Stuart S's Avatar
Below is the Comprehensive 165-Point Jaguar Approved Certified Pre-Owned Checklist.
Old Mar 7, 2023 | 10:57 PM
VegasFPace's Avatar
Ya know..this is about perfect, thank you
Old Mar 7, 2023 | 11:01 PM
VegasFPace's Avatar
yes....just waiting on possession of it. It has flashed a few Codes that have to be taken care of before i will officially take it and they cant legally sell it though. Wont pass smog. ( the battery was recently replaced so Im not sure if that is part of the issue also). Some of the codes do not clear immediately. Been using the search on here a bit lately and have already downloaded the shop manuals. Looks like i need an official jag code reader or something to get the other 2 digits on this code? (81,82,83 or 96)
any input on remedies for these....
Old Mar 7, 2023 | 11:45 PM
McJag222's Avatar
yes....just waiting on possession of it. It has flashed a few Codes that have to be taken care of before i will officially take it and they can legally sell it though. Wont pass smog. ( the battery was recently replaced so Im not sure if that is part of the issue also). Some of the codes do not clear immediately. Been using the search on here a bit lately and have already downloaded the shop manuals. Looks like i need an official jag code reader or something to get the other 2 digits on this code?
Graham responded to that code in an earlier thread:
Originally Posted by GGG
I've checked the 2009-12 XK Workshop Manual and Code B10AC references the Cruise Control Switch but without a scantool to report the associated 2 final digits, you won't be able to pinpoint the precise fault - there's 9 listed.
Old Mar 8, 2023 | 02:26 AM
VegasFPace's Avatar
In the shop manuals I cant find 9 issues that are associated with that code...only 4...... B10AC- 81,82,83 and 96
Old Mar 8, 2023 | 08:23 AM
Jaggyx's Avatar
Because I bought a 2013 Aston Martin V8 Vantage 6 Speed.
Amazing, congrats!
rsfan
Mar 13, 2018 12:57 PM
drbbop
Apr 25, 2017 07:11 AM
uclabrruin1989
Jan 1, 2017 03:29 PM
abhishriv
Oct 28, 2016 07:52 AM
