Control air-bag lighting
Old Feb 16, 2023 | 02:33 PM
MichalG's Avatar
Default Control air-bag lighting
Good morning everybody
The control air-bag is still lighting. The fatory reset didn't resolved problem.
Have you got any idéa how to turn off this control?
Thank you for your help (I cannot pass technic control).
Old Feb 16, 2023 | 08:15 PM
guy's Avatar
guy
Cannes. Oh dear… what code is being thrown? I have a feeling… and it is expensive.
Old Feb 17, 2023 | 03:42 AM
Originally Posted by MichalG
..... The control air-bag is still lighting. The fatory reset didn't resolved problem. Have you got any idéa how to turn off this control? .....
Welcome to the forums Michal,
It is the Airbag Warning Indicator lamp?
This is controlled by the RCM (Restraints Control Module) and, as you have found, a 'hard reset' does not clear the warning. Only finding and fixing the fault will clear it.
As a newbie, you cannot download the Workshop Manual from the forum so here is the relevant section showing the components in the restraints system:
The only effective approach to troubleshooting the fault, as suggested by guy in post #2 is to have the error codes read.
One simple thing to eliminate is circuit voltage. If your battery is suspect or partially discharged, this can set code B1A0016 which illuminates the warning lamp.
Old Feb 17, 2023 | 12:04 PM
MichalG's Avatar
Hello Graham.
Yes, this is light which is stil on.
Thank you very much for tour advise.
For a moment I don't know the error code (concessionnnaire didn't tell me).
Old Feb 17, 2023 | 01:44 PM
Hello Graham.
Hello Michal,
If you can get the code(s), post here and I'll look up the decode for you.
Old Mar 1, 2023 | 05:59 AM
MichalG's Avatar
Hello Graham
Finally I obtained report of diagnostic of my Jaguar.
There are lot of codes. For me this is a "magie noire".
I dan't know which code shows rho problem with air-bag control.
I join the report.
Thank you very much for your help
File Type: pdf
Old Mar 1, 2023 | 11:20 AM
It is not unusual to see a long list of codes as many recorded diagnostic codes are only reporting an out-of-range signal.
Your list has several error codes related to the instrument cluster (module de commande de tableau de bord):
B1D1787 - battery backup sounder
B108A29 - start button fault
B102613 - steering column lock open circuit
B100A63 - fuel pump authorisation timeout
B2A9016 - battery low
U015500 - lost communication with Instrument Cluster
U300087 - RJB missing message
U300055 - RJB incorrect configuration data received
U040181 - ECM/PCM invalid input signal
B1B7700 - front RH blend stepper motor actuator fault
B1B7600 - front LH blend stepper motor actuator fault
B1B7500 - panel/foot stepper motor actuator fault
B1B7400 - defrost stepper motor actuator fault
B1B3364 - target ID transfer signal plausibility failure
B1C3494 - steering column telescope solenoid unexpected operation
B100D96 - column lock authorisation low voltage
B1B0167 - key transponder start control unit invalid response
U300055 - stored vehicle configuration data does not match
U300049 - Instrument Cluster internal failure
U200531 - missing vehicle speed message ABS module or Instrument Cluster
B006164 - passenger seat belt tensioner
U300362 - battery voltage mismatch with navigation control module
Battery has caused a number of the errors and there is only one (B006164) directly connected to the restraints system.
Nothing in the list indicates a simple (low cost) possible cause and suggests the problem, if not a failing battery, is either Instrument Cluster or RCM (Restraints Control Module).
Old Mar 1, 2023 | 12:38 PM
MichalG's Avatar
Thank you very much indeed Graham.
I will change the battery first.
Michal
Old Mar 2, 2023 | 01:13 AM
Woo5ie's Avatar
I had intermittent air bag light coming on last year.
I didn’t get a code read out so wasn’t sure what was causing it.
It seemed to start when I started putting my electric golf trolley on the passenger seat.
I removed the passenger seat and checked all of the plugs and sockets were not loose.
Lamp still came on occasionally without anything on the seat.
I looked into possibilities that the seat occupancy pad was faulty.
I might add that I rarely had anyone seated in the passenger seat so the sensor which I believe is just a pad/bag in the seat with a sensor in it was never really used
so I made a point of taking a passenger .
All seemed OK after that so my theory which could be rubbish is that the occupancy sensor needed a reset by someone sitting on it. Been 9 months now with no air bag light👍
It was suggested ,it could have been on this forum , that if you have a smallish weight on the passenger seat then the system turns off the airbag assuming that there maybe a child sitting on it and lights the lamp as a warning.
I couldn’t find out that if this was the way it should work, certainly not in the manual.
Old Mar 2, 2023 | 02:51 AM
Originally Posted by Woo5ie
..... It was suggested ,it could have been on this forum , that if you have a smallish weight on the passenger seat then the system turns off the airbag assuming that there maybe a child sitting on it and lights the lamp as a warning.
You have to be extremely determined to find it.
Not well proof read by JLR. The word airbag is missing from the phrase 'the appropriate ....... will be deactivated'.
I find the deactivation warning comes on if I put the fairly heavy Sunday papers on the passenger seat.
Old Mar 2, 2023 | 05:01 AM
guy's Avatar
guy
:~). We are a dwindling breed. My papers may set it off as well… And many don’t read the papers any longer.
Old Mar 2, 2023 | 06:43 AM
Stuart S's Avatar
Michal
Michal,
Make sure that your new battery is fully charged before it's installed. Many brand new batteries aren't fully charged because they sit on the retailer's shelf for months.
A low battery causes many electrical gremlins. It's a common problem and the first thing to check. If your XKR is not your daily driver, you should keep it on a battery maintainer.
Stuart
Old Mar 2, 2023 | 01:26 PM
sov211's Avatar
And do check the connector under the seat!
Old Mar 3, 2023 | 04:09 PM
Woo5ie's Avatar
I didn’t realise that Sunday papers were so heavy these days. 🤔
When you get the alarm in this scenario does the airbag light light come on as well as the audible
Old Mar 3, 2023 | 05:25 PM
..... When you get the alarm in this scenario does the airbag light light come on as well as the audible
Just the passenger airbag deactivation indicator.
Old Apr 2, 2023 | 09:24 AM
MichalG's Avatar
Hello Graham and Stuart
Thank you very much for yours advises.
The battery has been changed last Friday (it was long time to get an appointment at Jaguar in Cannes ) and miraculously all of errors disappeared.
Everything seems be ok.
Michal
Old Apr 3, 2023 | 02:52 AM
Michal
Michal,
Pleased to hear it was a simple fix.
These vehicles are very sensitive to battery condition and charge. Using a battery tender will help prevent future similar problems. Most of us use one of the CTEK range,
Old Apr 3, 2023 | 06:44 AM
Stuart S's Avatar
Michal,
I'm also glad it was an easy fix!
Stuart
ajpds
Apr 21, 2015 03:44 PM
johney5
Feb 6, 2015 10:46 PM
Bleujag
Apr 14, 2014 02:08 AM
albackuk
Jan 28, 2012 12:58 PM
apollo022777
Apr 16, 2008 07:56 PM
