Convertible top does not seal
Old Nov 9, 2020 | 11:53 AM
e1heller's Avatar
Default Convertible top does not seal
Hello, I recently installed a new convertible soft top on a 2007 XK and the rear bow does not contact and seal against the tonneau cover. Are there any adjustments to remedy this????
Old Nov 9, 2020 | 11:59 AM
Coventry Foundation's Avatar
Was the New top factory or aftermarket please.
Old Nov 9, 2020 | 03:30 PM
Stuart S's Avatar
What's a 2007 XJXX? A typo? From your Public Profile:
Unless you installed the new top yourself, I'd bring it back to the shop that installed it and tell them to fix it. Because they didn't install the top properly, if you paid them with a credit card you should immediately dispute that charge in writing with your credit card issuer. Be sure to take photos to support your claim of unsatisfactory workmanship. If they fix it to your satisfaction, you can tell your credit card issuer to release the funds. Otherwise, you can demand a full refund and tell your credit card issuer to do a chargeback to that vendor. Read and follow your credit card issuer's rules about disputing a charge.
Old Nov 11, 2020 | 01:17 PM
e1heller's Avatar
It is an aftermarket top, but made by a company I have used many times.
I am inquiring if anybody knows of any adjustments that can be made.
Old Nov 11, 2020 | 02:18 PM
WhiteXKR's Avatar
Under the rear bow of the soft top there are 26 small torx screws that clamp down a curved plate clamp
that retains the rear of the top. You will need to stop the top mid stream to get access. Also this way the top is not under tension.
Loosen but do not remove all the the screws and make sure the top plastic tab material is fully inserted under the clamp while not under tension. Then retighten the screws in the order illustrated in the picture to 4 NM each. This should work unless the plastic tab on the new top has been damaged.
Once this is done you will need to reset the top by stowing it manually per the owners manual instructions.
Old Nov 11, 2020 | 08:24 PM
Stuart S's Avatar
oldguy
Oct 30, 2024 08:33 AM
XKR1985
Jun 3, 2020 05:12 PM
DougXK8
May 25, 2020 08:29 AM
1988xjs12help
Feb 19, 2020 10:35 PM
Dercent
Mar 4, 2018 03:48 PM
