Coolant leak,and top hose hard
Old Aug 23, 2023 | 09:44 PM
Ghost60's Avatar
Default Coolant leak,and top hose hard
Hey guys can someone please advise me, my 2007 jaguar xk, shut down and restricted performance message prompted ,I noticed a small amount of coolant near passenger front side under my vehicle, could this be a thermostat issue please advise
Old Aug 23, 2023 | 11:39 PM
kj07xk's Avatar
Thermostats on these cars usually stick partially open, not closed, but anything is possible. Probably need to take off the under tray to see where the leak is (if you can’t find anything up top). For a passenger side leak, I’d be suspicious of the expansion tank, notorious for leaking due to a cracked lower nipple.
More importantly, why did the car shutdown? Did it overheat? Any other display messages? Any codes posted?
Old Aug 24, 2023 | 08:39 AM
Ghost60's Avatar
Yes,it through several codes, the leak seems to be near the front of passenger side, or at least where it drips, it seems that the top hose has alot of pressure
Old Aug 24, 2023 | 02:23 PM
sony2000's Avatar
I posted of a coolant leak in the 2007 near the coolant container but under the manifold cover.
Old Aug 24, 2023 | 02:28 PM
sony2000's Avatar
I labeled it "Antifreeze leak" on August 3, 2023.
Old Aug 24, 2023 | 04:37 PM
Ghost60's Avatar
How can I find your post on antifreeze leak,having trouble finding it,please be gentle I'm new to this,lol
Old Aug 24, 2023 | 04:46 PM
Cee Jay's Avatar
"Antifreeze connector fell apart!" ?????????
https://www.jaguarforums.com/forum/x...-apart-272285/
Old Aug 24, 2023 | 04:50 PM
Ghost60's Avatar
Thank you, very much appreciate it on it
Old Aug 24, 2023 | 05:14 PM
McJag222's Avatar
Tow the car out of the environment.
Old Aug 24, 2023 | 06:06 PM
sony2000's Avatar
I doubt this is the source of your leak but it is a hidden fault. I replaced it with a 3/8" copper plumber's pipe and two adjustable stainless clamps.
Remove the manifold cover and see if there is any coolant lying around there.
Old Sep 3, 2023 | 02:40 PM
sony2000's Avatar
From another reading here, I realized there are other connectors on the coolant system, that crumble apart. Lets try to locate each one. One was said to go behind the block to the drivers side.
Old Sep 3, 2023 | 04:49 PM
justinhill's Avatar
Reading this I just remembered when a coolant leak on my xj 4.2 caused a bunch of codes. A flood in the valley killed the knock sensors.
Old Sep 3, 2023 | 06:39 PM
bocatrip's Avatar
There really should be a sticky thread... Owners of XKs (2007-2015) should be aware that sooner or later ( usually sooner) ALL plastic coolant line/pipes/hoses must be replaced as a maintenance item.. Lack of maintenance can lead to catastrophic engine failure.
Old Sep 4, 2023 | 05:51 AM
Barry Leftwich's Avatar
The intake hose melted on my 2007.It's different on the last gen model I have and I think they been replaced with better material so that no longer happens or else I would have experienced it again by now since the last gen XKR have more miles than the 2007 XKR I had
EscapedApe
Aug 6, 2017 06:08 PM
hawaiianjag
Feb 8, 2016 08:52 PM
Jagamadryer
Apr 18, 2015 07:47 AM
ferrytrip1
Dec 19, 2014 12:41 PM
