Is the coolant premixed?
Old Sep 4, 2015 | 01:48 PM
ejjbee's Avatar
Default Is the coolant premixed?
jlm209723 jaguar antifreeze. Does one need to add water to this is it already premixed? cheers!
Old Sep 4, 2015 | 02:35 PM
Mikey's Avatar
It's not premixed AFAIK.
There's no need to buy pricey Jag branded fluids for your car. It's simply standard coolant that's been repackaged.
Old Sep 4, 2015 | 03:03 PM
ejjbee's Avatar
Thanks, Mikey. That is my impression as well, but I can't be 100% sure. Not that it should really matter a lot for a very small top up, or does it?
Old Sep 4, 2015 | 03:16 PM
Mikey's Avatar
Depends on what's already in the car's system. Best test it to be sure.
Old Sep 4, 2015 | 03:26 PM
ejjbee's Avatar
It is the same orange stuff.
Old Sep 4, 2015 | 03:41 PM
It's concentrate here's the link to the spec sheets.
https://www.google.com/url?sa=t&rct=...,d.cWw&cad=rja
Old Sep 4, 2015 | 04:01 PM
ejjbee's Avatar
Norri, you're great it is specced as a concentrate! Many thanks!
Old Sep 4, 2015 | 04:30 PM
Mikey's Avatar
No, I meant what is the present coolant/water ratio of the coolant already in the car? The ideal is 50/50.
Old Sep 4, 2015 | 04:39 PM
ejjbee's Avatar
How can you tell?
Old Sep 4, 2015 | 05:31 PM
Mikey's Avatar
Handy dandy tester
Prestone Antifreeze Tester - Walmart.com
Old Sep 5, 2015 | 10:07 PM
RedRider48's Avatar
Also, there are testers for testing the protection strength of coolant, as well.
Old Jan 26, 2019 | 11:53 AM
STEELVALLYGUY's Avatar
Default Jaguar Coolant color.
If your Jaguar is still under warrenty then use the Jaguar branded coolant as Im doing. Its orange in the jug but when you pour it on the ground or in a pan it turns yellow/green.
MrWhite
19
Jun 14, 2022 07:49 PM
X308XJR
May 20, 2019 06:50 PM
04Xjrsteve
May 7, 2019 04:06 PM
vwbusbits
Oct 13, 2015 03:43 AM
