Coolant reservoir bleed screw / plug part sourcing
Old Feb 5, 2024 | 04:06 PM
trkyam's Avatar
Default Coolant reservoir bleed screw / plug part sourcing
Anyone know where I can source the correct part for the coolant reservoir bleeder screw?
I believe it is 13mmx1.5 bleed screw. I've already replaced the reservoir so I just need the screw
the screw is made of hollow plastic fill and if you overtighten, it will shear off.
all of the ones I found online are 10mm and do not fit XKs/F-types etc.
Old Feb 5, 2024 | 04:57 PM
trkyam's Avatar
I can confirm, LR055301 smaller diameter 10mm and is not the correct bleed screw.
Old Feb 6, 2024 | 10:54 AM
trkyam's Avatar
UPDATE: There are 2 sizes being sold under the same part number, you will have to ask the seller
to put a micrometer on the plug. Currently britparts is selling it on amazon/ebay
Old Feb 6, 2024 | 11:42 AM
sony2000's Avatar
Try the plastic bolt commonly used to hold license plates to a car's body.
Old Feb 6, 2024 | 01:16 PM
trkyam's Avatar
I wouldn't recommend using a license plate screw, you might mess up the threads.
This is also a bleed screw that is suppose to allow some flow from hose to reservoir
even when closed shut.
Old Feb 7, 2024 | 07:44 AM
sony2000's Avatar
There could be a 50% chance a plastic bolt has the same thread size. Add an 0 ring for seal and drill a hole vertical and horizontal for air flow. Finding the replacement bleed screw, will only come with a complete tank. Just another Roadkill repair!
Old Feb 7, 2024 | 04:06 PM
xalty's Avatar
all the wallet rovers have that screw
Old Feb 7, 2024 | 04:55 PM
trkyam's Avatar
britpart sells the correct size under the same part # LR055301 but be advised most sellers will
send you the 10mm plug which will not fit XKs F-types
https://www.ebay.com/itm/153760911404
deftone
Sep 6, 2024 04:07 AM
Brian H Smith
Nov 12, 2022 03:01 PM
XKRAU
Jan 22, 2021 01:12 PM
Wuzupez
Dec 27, 2014 04:41 PM
XJL
Jul 27, 2013 06:26 AM
