Coolant Temps in Hot Weather
Old Jun 28, 2019 | 09:34 PM
  #41
jagtoes's Avatar
Originally Posted by Dave Gale
Where do i get one of those.......2010 xkr
Look up SCANGAUGE
Old Jun 29, 2019 | 09:27 PM
  #42
Reverend Sam's Avatar
Originally Posted by DannyJ
I use this one. It shuts down and wakes up fine each time
I just installed that same one. The buttons are a little confusing, but it's relatively subtle on the dash. I used the reflective film because I can't stand the double reflection from the glass.
Old Jun 30, 2019 | 12:40 AM
  #43
DannyJ's Avatar
Agree about the buttons...
How about a picture with the reflective film ? Does it interfere the view?
Old Jun 30, 2019 | 12:55 AM
  #44
peterv8's Avatar
Or like this!:-)
The reflector is just a thin alloy sheet that I bent and painted with a grey metallic spraycan I had lying around. If you think it's to dim you can allways put a piece of reflective film on there and it will look brighter and sharper.:-)
Old Jul 2, 2019 | 06:07 PM
  #45
I held the camera right next to my eye to take this pic. I'm 6'3" and 14 stone, so I probably sit a little higher than most people. The film doesn't bother me at all. I bought that HUD and positioned it there after seeing your pic. I'd like to move it forward a little, but if I do then I can't use my fancy Jaguar sun shade.
Old Jul 2, 2019 | 06:11 PM
  #46
I just realized that in that one pic you can see my HUD, my dash cam (with GPS and rear view cam), and my rear view mirror backup camera.
Old Jul 3, 2019 | 08:23 AM
  #47
110reef's Avatar
Does the A100 HUD also read in F?
I am seeing in the listings that it is not compatible with Jaguar, but I see it is working with Rev Sam and Danny J.
Do you guys recommend it?
Old Jul 3, 2019 | 08:36 AM
  #48
DannyJ's Avatar
It works fine for me showing the temp which I believe is essential info in that car
I liked this one as it is very compact keeping the beautiful jag dash lines free as they should be
Old Jul 3, 2019 | 06:17 PM
  #49
This is the exact one I bought. It can be set for metric or "normal" It has some quirks, but for $20, it can't be beat. The controls are downright silly. I'm to the point now where I can switch between speed, temp, and voltage with no problem, but I have to pull out the little instruction sheet to do anything else.
But like I said, for $20 it can't be beat.
https://www.ebay.com/itm/3-5-A100-Ca...72.m2749.l2649
Old Jul 3, 2019 | 08:40 PM
  #50
jagtoes's Avatar
That won't work for us in NY . The inspection sticker as well as the registration sticker are located there.
Old Jul 3, 2019 | 08:50 PM
  #51
Cee Jay's Avatar
AVG FUEL 19.6?????? Man, you gotta put your foot into it more often.
Old Jul 4, 2019 | 08:10 AM
  #52
LOL! Ever since I blew my water pump at full throttle I've been leery of stomping on the gas pedal.
I still do it occasionally, just not as often.
Old Jul 4, 2019 | 08:13 AM
  #53
In that case, it's the perfect place to put the reflective sticker. Your view is blocked there anyway. Put some reflective tape over the other stickers and use it to see the HUD. The cops are only going to be looking at the inspection/registration stickers from outside the car.
Old Jul 4, 2019 | 08:22 AM
  #54
jagtoes's Avatar
I found my solution as acceptable so I don't need to go with yours . Also the inspection sticker gets removed and replaced every year. You knw the tax man gets us here.
Old Jul 5, 2019 | 08:12 AM
  #55
110reef's Avatar
Thanks. Ordered!
Old Jul 18, 2019 | 08:07 AM
  #56
110reef's Avatar
Tried to install mine yesterday. Initially it seemed to display the temperature but while paging through the setup screens, it no longer seems to display the temperature, rather it displays "03". Perhaps some type of error code. MPH and voltage seem to work just fine, but my main interest was temperature. I unplugged from the OBD port and plugged back in, I unplugged from the back of the unit and plugged back in. I shut down the car and started back up. Nothing worked.
Old Jul 18, 2019 | 10:04 AM
  #57
DannyJ's Avatar
Strange...
Did you check with the seller?
Old Jul 18, 2019 | 11:34 AM
  #58
110reef's Avatar
I sent them a note just now. Didn't know if anyone else may have had this problem.
Old Jul 18, 2019 | 09:38 PM
  #59
Once you go over 200 it drops the first digit. 03 means 203.
Old Jul 18, 2019 | 10:21 PM
  #60
badicedog's Avatar
Mine runs 210 degrees on 90 degree hot days. Going to try 30% coolant to 70% distilled water...
