Coolant Temps in Hot Weather
Old Jul 19, 2019 | 07:06 AM
  #61
jagtoes's Avatar
Originally Posted by badicedog
Mine runs 210 degrees on 90 degree hot days. Going to try 30% coolant to 70% distilled water...
210 is not considered a problem and all new engines usually run around that temp. My 5.3l GM truck's recommended sweetspot is 210 and it runs at it all day regardless of outside temp. MY XKR runs around 207 normally which I consider a non issue.
Old Jul 19, 2019 | 08:20 AM
  #62
110reef's Avatar
Originally Posted by Reverend Sam
Once you go over 200 it drops the first digit. 03 means 203.
Are you serious? If so, that would explain it I suppose.
Old Jul 19, 2019 | 07:41 PM
  #63
Reverend Sam's Avatar
Yes, I'm serious. And stop calling me Shirley.
The HUD has three digits, but the first digit is just a "1". It's either on or off. If you're driving 75 it's off. If you're driving 105 it's on.
If you have it set to show coolant temp and the temp is 75, it's off. If the temp is 175 it's on. If the temp is 205 it's off. The display will just read "05".
Old Jul 19, 2019 | 07:50 PM
  #64
Sean W's Avatar
Old Jul 19, 2019 | 07:54 PM
  #65
I'm glad someone got it. :-)
Old Jul 20, 2019 | 01:53 PM
  #66
110reef's Avatar
Thanks! I re-installed it and yup, over 200 and I just get the last two digits. Which is fine, so I am keeping it. The highest I have seen it run was 204 so far.
Greg in France
Jun 2, 2018 05:39 PM
Vee
Nov 22, 2014 08:04 PM
PEM24
Jul 31, 2013 07:56 AM
Rey
Diesel variants - All models
May 2, 2013 06:51 PM
