CTEK Install Question
Old Sep 16, 2015 | 12:43 PM
SeanU's Avatar
Default CTEK Install Question
Sorry for all of the questions... I'll ease off in a little bit.
I just got my CTEK 3300 and extension cable. I'd like to mount the connector it under the front hood, and keep the connector accessible from the front of the car without popping the hood. Anyone have a setup like this with recommended routing path for the cable?
Old Sep 16, 2015 | 12:50 PM
jimbov8's Avatar
Red face
The correct method is to connect the positive direct to the battery and the negative to the ground stud in the boot/trunk.
Your car your choice but this is clearly written in the manual, if you have one.
Old Sep 16, 2015 | 03:44 PM
tampamark's Avatar
I looked for under the hood mount points and didn't see anything. The Jump Start terminals are in the trunk and easier than digging out a direct connect to the battery. I am going to put my quick connect trickle charge cable there.
I am out of town so going by memory as I had scoped out my placement already. If you go to the trunk, remove the plastic hatch in front of the drivers side stop lights, at the bottom against the left fender there is a rubber boot cover over the positive terminal. The Jump ground is somewhere in the middle, I didn't look for that as I am planning on using one of the other bolts if it could provide solid ground.
Old Sep 16, 2015 | 04:45 PM
Stuart S's Avatar
There are lots of threads on this X150 Forum about how to install a CTEK or other battery maintainer, complete with detailed instructions and photos. Learn to use the search function. Many questions have already been addressed and you don't need to reinvent the wheel.
I'll post links after I get home and can use my PC. This reply is from my cellphone.
From my PC:
See these links of most helpful/most viewed:
https://www.jaguarforums.com/forum/x...ook-up-147682/
https://www.jaguarforums.com/forum/x...lation-107738/
https://www.jaguarforums.com/forum/x...lay-ups-73471/
Full list on the X150 Forum (63 threads): https://www.jaguarforums.com/forum/s...archid=4771227
If this was helpful, please press at the bottom right.
Stuart
Old Sep 18, 2015 | 08:09 AM
SeanU's Avatar
Default Ok... installed in the boot
After reading everyone's advice, I did the standard install in the trunk. I will get the cigarette lighter socket at some point to make it cleaner. Thanks everyone!
aholbro1
Dec 29, 2024 06:46 PM
H20boy
Dec 24, 2024 03:23 PM
Dz1rfj
Jul 17, 2018 10:29 AM
fingers
General Tech Help
Oct 21, 2015 02:02 AM
jagent
Sep 12, 2015 01:40 AM
