Custom Carbon Fiber XKR Engine Appearance Cover
Old May 25, 2020 | 11:13 AM
  #41
Stuart S's Avatar
Originally Posted by AlexJag
You can do a lot more: Bosch 010 pump, lower temp thermostat 180 , ECU programming for lower start ,duration and speed of the main fan. With this combination mine stays around 190- 195
That's not free, and does nothing to reduce the engine compartment temperature caused by heat from the exhaust manifold and pipes. Your 195°F internal engine temperature is much lower than the engine compartment temperature, particularly when you run your car hard. All I'm saying is that you can prolong the life of the rubber parts in your engine compartment simply by opening the hood when parked, and that costs nothing.
Old May 25, 2020 | 07:52 PM
  #42
The Doctor's Avatar
I was thinking of doing this on my new cat. I am currently testing a kit to do the 2 side covers first, then I may tackle the main engine cover. But if I can get it for $185 like Stuart, then I may just go with that. Ill post if Iget something worthwhile.
Old May 25, 2020 | 07:58 PM
  #43
Stuart S's Avatar
Note that the red paint in the "SUPERCHARGED" lettering cost $20 and was included in the total $185 cost. But that was 6 years ago and prices probably went up.
Biggriff
Mar 16, 2022 07:25 AM
richzak
May 20, 2020 11:05 PM
hdavidson
Feb 21, 2016 10:54 AM
romello424
Nov 18, 2015 06:12 PM
buickfunnycar.com
Sep 23, 2014 04:54 PM
