Differential yoke leaking....
Old Jan 17, 2019 | 07:52 AM
‘Oleguy's Avatar
Default Differential yoke leaking....
I have a spraying effect on the underside of my car in the area of where the driveshaft connects to the yoke.
Where the seal is located at the differential and the yoke penetrates the housing is bone dry.
Is there an o-ring or another seal in this area?
Does anyone have or or has anyone seen this issue? Repair suggestions?
Thanks in advance!
Old Jan 21, 2019 | 07:52 AM
flyc2c's Avatar
U-joint? I'd disconnect the driveshaft and check.
Old Jan 21, 2019 | 11:01 AM
Ranchero50's Avatar
What is it spraying? Oil or something dry?
Our cars don't use U joints, but a rubber doughnut that connects the shafts to the drive line.
Old Jan 23, 2019 | 07:20 PM
flyc2c's Avatar
Forgot about the rubber doughnut. Duh (on me).
Old Jul 29, 2019 | 03:13 PM
DannyJ's Avatar
Thanks in advance!
How did that leak evolved or solved ?
Seems I see some similar issue
See picture below
Old Jul 30, 2019 | 07:17 AM
‘Oleguy's Avatar
Car has taken 1st place 2 yrs now D-11 class Concorse’De Elegance
I have not done anything at the moment. I have been trying to locate a Quafie rear for it. Actually another housing and rebuild it with Quafie assembly, seals etc and do an entire diff changeout.
It does not drip onto the garage floor. I did have the fluid changed out which was really dark. I have an BMW/Mercedes independent mechanic about 2 miles from house really sharp and v reasonable. I’d have him do it. We already discussed. I’m getting to old to work without a lift.
I spkoe to the Jag dealer here and they said $425-500 to fix the leak. If it’s not dipping I’m leaving it until I get another diff.
Old Jul 30, 2019 | 08:49 AM
DannyJ's Avatar
I tend to agree that no drip is no leak but still want to be ready for the drip which will probably follow...
I think I will buy the pinion seal and new fluid and take care of them both once I'm in there.
Not sure if the shaft need to be completely removed for changing the seal or just remove the rubber doughnut ?
BTW what fluid for the 4.2L N/A ?
Old Jul 30, 2019 | 10:55 AM
Ranchero50's Avatar
See picture below
DannyJ, you are leaking around the nut that holds the yoke onto the pinion shaft. The '03 and up Lincoln LS diff is a direct swap and you can get 3.31 or 3.58 gears. I went with the gears and haven't felt the need for a posi unit yet. I have pics in my build thread of the swap. Overall not a hateful process.
Old Jul 30, 2019 | 11:42 AM
‘Oleguy's Avatar
Ranchero,
Can you send / post the link to your direct swap to the Lincoln Limited Slip diff.
Danny as Ranchero stated per the pics it’s NOT you yoke shaft seal (pinion). As for fluid I used 75/140 full synthetic.
Old Jul 30, 2019 | 04:27 PM
DannyJ's Avatar
Thanks Ranchero for the suggestion to swap the diff but I'm afraid LS cars are not popular here around so I will stick to the current diff
I did read you thread anyway. Great info and writing
If the leak is from the nut area will it be enough to remove the yoke and put some RTV on the pinion or is it the oil seal behind the yoke which should be changed anyway ?
Old Jul 30, 2019 | 04:30 PM
DannyJ's Avatar
Yes, I understand that but still not sure how oil could be leaking through the nut without a bad oil seal ???
Thanks for the oil code
Old Jul 30, 2019 | 04:59 PM
Ranchero50's Avatar
I want to say there's a molded O ring into the nut's face to seal the pinion spline to yoke fit. I think I have the spare floating around and will check it when I get home.
Old Jul 31, 2019 | 01:18 AM
DannyJ's Avatar
Great Ranchero, I will really appreciate it
Old May 20, 2023 | 05:34 PM
‘Oleguy's Avatar
Default Fixed finally
Well 56$ seal $1282.00 total at dealer in Cockeysville MD.
4 different local shops all said that they needed 4-6 special tools to change the seal. It seams that seal is in it own carrier.
we’ll I don’t have to smell vaporizing gear oil now.
Dare
Oct 3, 2020 09:04 AM
xjfourty
Nov 21, 2018 02:55 PM
flatlander
Mar 20, 2017 10:18 AM
AL NZ
Mar 16, 2017 11:46 AM
Eagle
Nov 27, 2012 06:52 PM
