Dim cluster
Old Apr 30, 2018 | 11:46 PM
Brian123's Avatar
Default Dim cluster
Hi there, I'm hoping someone may be able to help me solve the problem I'm having with the instrument cluster in my 2009 XK. When I start the car in the morning the screen between the speedo and rev counter is very dim and I struggle to read the information. After about 10 minutes it brightens up and is fine for the rest of the drive only to repeat the following day. I have a new battery in the car and the alternator is working fine. The dealer said this was very common in older cars but I'm not so sure. Before I paid for the car 3 weeks ago the cluster was removed and checked but it seems the specialist was unable to replicate the problem and it was refitted to the car with the issue remaining. Any help would be much appreciated.
Old May 1, 2018 | 05:32 PM
avern1's Avatar
There should be a dial on the right side of the steering column that adjusts the brightness of the cluster. It sounds as though yours may be failing. As the witch heats up it is getting brighter. You might try spraying it with electronic cleaner and see if if it just corrosion causing the high resistance. The dial is a rheostat that can be turned up and down to control brightness. The higher the resistance the dimmer the lights.
Old May 1, 2018 | 06:40 PM
Originally Posted by Brian123
Hi there, I'm hoping someone may be able to help me solve the problem I'm having with the instrument cluster in my 2009 XK. .....
Welcome to the forum Brian,
I've moved your question from General Tech Help to XK/XKR forum. This is the place to post technical questions about your model. I've also deleted the duplicate from New Zealand Region forum.
Old May 1, 2018 | 06:57 PM
Brian123's Avatar
Thank you for taking the time to reply to this question. I've had it in to two auto electricians and the later one suggested it was the transformer in the cluster which powers up the LED screen I called the dealership and they could only supply a complete unit at $5000! They told me a second hand unit would not work in my car...
Old May 1, 2018 | 08:15 PM
khsjsilver's Avatar
Brian,
I have gone through the whole process of replacing a failed instrument cluster. Take a look at the following link:
https://www.jaguarforums.com/forum/x...roblem-191580/
Hope this helps.
Ken
Old May 1, 2018 | 09:58 PM
Brian123's Avatar
Thanks for taking the time to reply Ken! Sounds like you have been through a lot with your car!
Old May 3, 2018 | 08:53 AM
LoudHogRider's Avatar
Originally Posted by khsjsilver
Brian,
Hope this helps.
Ken
Well, that was educational and informative ... and depressing. I've recently begun experiencing the same "dim at start" issues that Brian is, and am dreading the replacement cycle you experienced. Electronic failures are a part of owning a 10-year old vehicle, and eventually it will be the reason I release my cat into the wild.
car5car
May 5, 2017 09:31 AM
Tracy Weiland
Aug 28, 2016 11:34 PM
car5car
Jun 26, 2016 05:33 PM
dwight looi
Apr 28, 2015 04:07 PM
AL NZ
Oct 30, 2013 08:11 AM
